Question about Acer Computers>Laptops Aspire 5610-2328 PC Notebook
Screen wont come on
Its like its in hybernation,the computer will turn on,but the screen will not.
  • Acer Master
  • 2,404 Answers
No video on the screen. Reseat the memory one stick at a time in each slot one at a time and try turning on the laptop after each stick reinsertion to see if you get video. If not then the motherboard is bad.
Posted on Jun 20, 2009
My dell says hybernating while on and hang
Hybernation is a power saving feature in microsoft windows. Often times this will cause the computer to freeze.
One solution is to disable hybernation in the power settings located inside the control panel.
On windows vista / 7 you can do this by clicking on the start button (lower left hand corner of the screen)
Then going to "Control Panel"
At the top right of the screen should be a search box, simply type "Power" Into this box and options to edit / change the power plan should appear. Choose edit power plan,
Make sure any options pertaining to hybernation are disabled, You can also adjust when the screen and hard drive shut off during inactivity. For desktops it is recommended to set all options to "Never"
Once finished click the "Save Settings" Button. and you are all set.
You can adjust these settings as much as needed, they can always be undone.
On windows 8 you can access the control panel by moving the mouse to the upper right hand corner of the screen and choosing "Settings" or "Computer Settings" the same procedures apply after this step.
Nov 20, 2014 | Computers & Internet
Dashboard
Hybernation is probably turned off.
to turn it on
start -> control panel -> power settings -> hybernation tab
enable hybernation.
I'd recommend you reinstall the driver software for your dashboard screen / video card.
Do you have the cds or should I get you a download?
May 19, 2008 | Gateway m1300-3004372 Tablet PC
1525 wont come out of hybernation and the battery wont hold a charge either. Ive tried removing the battery, pushin the power button, lettin it die n try bootin up. Its stuck in hybernation, help me...
Hybernation is one of the worst idea's that microsoft has come out with, it usually ends up corrupting windows making it useless. The only option is a fresh install of windows, and I recommend the hybernation feature be disabled. The battery may start to charge when the new operational windows is running, if not! replacement needed.
Apr 14, 2012 | Dell Computers & Internet
SCREEN GETS STUCK IN HIBERNATION MODE
To disable Hybernation try:
right click on empty space of the screen
select property
select the tab "Screen saver"
click the button power on the right bottom
another window will pop out
select the tab "power option properties"
uncheck the checkbox "enable hybernation when it is checked
Mar 09, 2011 | LG Flatron L1750S 17" LCD Monitor
How to open when computer is hybernated
as you start it normally-just press the power button and you are done
Dec 09, 2010 | Acer Aspire 4730-4947 Notebook
My laptop scrren not show immedetly and all thing is working .
have you changed your screen mode 'Function key and F5' changes the output of the screen ensure your screen is set right.
Have you got hybernation on?
reboot and turn off hybernation.
AndystUK
Aug 30, 2009 | HP G70t Notebook PC
What would cause your power button light on the monitor keep blinking and the screen is black and you have trouble getting the light to stay on and get the picture back on. what is the problem. thanks,...
If the button on monitor is blinking, it means your computer is either turned off or in standby mode (or in hybernation).
You should push the power button on your computer to restore it from standby (or hybernation).
Aug 09, 2009 | Acer Computers & Internet
My A105 Toshiba Satelliet is stuck in hybernation and will not come back on
hi dear
oke ...try to remove the battery from your notebook, try on with only adaptor
after normal you can put your battere again
thnks
cropp
Mar 17, 2008 | Toshiba Tecra 8100 Notebook
Acer Computers>Laptops Aspire 5610-2328 PC Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
