Question about Nokia 7360 Cellular Phone
No signal change power amp.theres no result
  • yadayada
    yadayada Feb 17, 2012
    This is a cell phone?
    Top Expert:
  • Nokia Master
  • 1,575 Answers
Try removing the simcard and re-loading it again.
Posted on Feb 18, 2012
Why is there no sound when I press unlock button on my remote key, and also when I lock it.
About 2,120 results (1.07 seconds) Search Results
    Why is there no sound when I press unlock button on my ...
    www.fixya.com/.../t26080674-no_sound_when_press_unlock_button_re...
    1 hour ago - Question about 2002 Oldsmobile Bravada. Open Question ... The chime sound that should signal that I am unlocking my 2002 Oldsmobile Bravada, andshould also signal when I lock it is not working. Posted by francisco_al on Feb ... T & C 2001 REMOTE CONTROL PROGRAMMING. Sep 17, 2012 ' 2001 ...
    Oldsmobile Forum Repair Questions- Newest Answers
    www.greatautohelp.com/oldsmobile.php
    1995 oldsmobile achieva dash and tail lights don't work! ... My car, 98 intrigue, has the automatic climate control and will not change ... Usually the whining noise stops just before it stalls. ... I have a 2002 Olds Bravada I bought during cold weather. ... both the cam and crank sensor send their signals to the ignition control ...
    [PDF]
Feb 03, 2016 | 2002 Oldsmobile Bravada
Hi! i have hitach CRT tv has a problem of switching. the power supply is okay but there is no horizontal signal.I have changed the video amp TDA 8362 but still the same problem.
You need to check if you have horizontal drive to the base of the horizontal out transistor. With a scope check the primary and secondary of the horizontal drive transformer to find out where you are losing the drive.
Feb 01, 2015 | Televison & Video
TV Reception
All structures - including trees can interfere with reception of radio or TV signals. Some are worse than others ie: a brick wall directly in front of the antenna (between it and the station) is far worse than I tree is. If you are unable to relocate the antenna - you may get relief by RAISING it. If that is not possible, you can try adding a powered (called "active" as opposed to un-powered or a "passive") inline amplifier. This will boost all signal levels, including "noise" but usually results in a better picture. Change the antenna itself to one that offers more GAIN - and add the amplifier if the antenna change alone is not enough. Finally, a directional antenna, pointed directly at the transmitter is the best "over the air" method of reducing "multi-path" (a common cause of "ghosting") and other types of signal interference. You can try all these at the same location as the omni-directional antenna so, they aren't really resulting in "relocation". An excellent source for information that can be custom tailored to your specific location and channels you like top watch can be found at: http://www.antennaweb.org
I hope this helps & good luck!
Jan 27, 2014 | Grilling
Front left turn signal doesnt work
The turn signal circuit is different from the parking lights. So the headlights would not be involved.
You should have power on one side of the bulb for parking lights and the other for turn signals.
If you have no power for the turn signal circuit, I would look at the turn signal switch. It powers each bulb separately.
Aug 21, 2012 | 2005 Saturn Ion 2
I have an SWR workingpro 2x10c combo solid state amp. When running a signal into the standard input with all pots set at 12 o clock, the signal sounds very distorted. I have tried a basic troubleshoot,...
You haven't told us what "signal" you ran in... Make sure ALL interconnected equipment is powered from the same receptacle. All audio lines should use balanced interconnects where possible using XLR or TRS cables. Cross connect another amps preamp into the effect loop input to check the power amp portion.
Dec 15, 2010 | SWR WorkingPro 15 Amp Combo Bass
Hey, the clean channel on my Marshall 250dfx Combo amp isnt working the distortion and everything is working as normal, but the clean channel makes no sound at all, i was wondering if you can help?
The switching is done electronically by an analog gate chip. On IC9, check if the signal on pin 8 changes with switching between clean and OD... This is the actual signal that changes the gate. If you don't see a change there of say 5 volts, then the problem is in the circuits that drive this gate. If the signal is there, then the problem is in the clean channel audio op amps or the components around them. Let me know the results of the test.
Oct 18, 2010 | Marshall Amplification Marshall MG250DFX...
When I play my Line 6 Spider III Amp (Stack), the volume and gain output is very weak even though the settings are maxed, and the tone is very strained and sharp. It basically lost all of it's kick.
Poor contacts at jacks can cause this... it results in the contacts acting like a small capacitor passing only the high frequencies at very low level.
Power amp inout jacks are notorious with switch contacts that pass the preamp signal to the power amp if the power amp input isn't used.
There are many other possibilities and only hands on troubleshooting will determine the cause.
Jul 23, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
When i turn it on,it has a signal. after a few seconds, the signal disappears
hi,
use some other phone providers sim and check if the status of your phone is the same...if the same lets go to troubleshoot your phone..
before changing any parts of your 3120 lets do the step by step procedure in repairing no signal problem of 3120...
1.)go to menu
2.)settings
3.)phone settings
4.)network selection
5.) then select manual
then if the result is NO NETWORK FOUND,
you need to change 2n2 capacitor ...
if you got any network in your selection ,you need to reolace your power amp...
if it is searching so long your phones mjoiner is damage and need to replace..
i hope it will help you ,thanks for trusting fixya..
Jun 23, 2010 | Nokia 3120 Cellular Phone
No sound on right channel. no output on right channel. already change power output ic's, but no result. SU-V10X amplifier. Panasonic Technic
Take a look if your outputrelay is switching on.
If so, then measure if the signals coming thrue.
Offcourse only if you are sure that there is a signal present.
Regards,
Gerard
Jan 18, 2010 | Technics Audio Players & Recorders
Nokia 7360 Cellular Phone Logo
26 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
