The user programs are no longer the speeds I want. I changed the speed while running the program, which is what the owner manual says, but the program still goes back to the settings I programmed originally.
Dear Sir:
Please adjust the sensor speed see the diagram attached. 2) Tight very well the wires from sensor speed. 3) I vey STRONG recommend you to RUN your software calibration for easy Diagnose +Troubleshooting most of them is coming the instruction from the Hood of motor, or use your instruction manual.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
SOURCE: I have a Proform 545s treadmill with incline and
i have a proform 545s as well and it would light up when pluged in but you could not use the speed settings at all. i figured out how to fix it just by tinkering around with it. i removed the back cover on the programer up top and exposed the circiut board. there is are 2 ribbon like sets of wires that come from the speed controler. the plug into the circuit board with a whit clip. pop loose the white clip on both of there and you will see a series of prongs that come in contact with the ribbon. using a small flat head screwdriver you must bend these prongs in slightly to close the gap between the two. it took me a couple tries to bend them enough to make contact again. i tried it and to my surprise it works great. the fan still is not working but i am trying to trouble shoot that now. hope this helps you....
