Question about Toshiba Televison & Video
What does a constant orange blinking light mean on Toshiba model number 42rv530u
4 Suggested Answers
SOURCE: No Picture on Toshiba 42RV530U
I had a similar problem to this yesterday. Tv is same Toshiba model as you mentioned about 4 months old. In my case, after the TV working perfectly following installation, the standby LED on the front (the one that is red on standby and green when on) went to a flashing orange (after switching on from standby) and the picture disappeared although the sound remained OK. I was unable to get any response from the setup or menu on the remote, otherwise I would have tried resetting the TV. Regardless of how much switching off/on (including disconnecting the powerlead and leaving for few minutes), disconnecting all peripherals, etc., nothing helped. I looked up Toshiba's web site and under support they basically suggest switching off the TV and restarting using the onset buttons (not the remote) and pressing the menu button (again the one on the set (not the remote) and if you could get the menu box to appear then reset to default settings. I tried this but the results were the same. I therefore thought the TV was defective. However, after much frustration I did the following (I think): 1) Disconnect everything from the TV 2) Powered up from the mains switch whilst keeping BOTH the startup and menu buttons on the side of the TV pressed down. The result in my case was that the standby led and one of the two beside it flashed green simultaneously. However, when the buttons were released, the TV started up the same (flashing LED orange and sound no picture). 3) Pretty well defeated at this point, after doing the procedure at (2) several times with the same results, I somehow thought of pressing the standby button on the remote either whilst the two buttons on the set were depressed or just after they were released. I am afraid I cannot remember which and cannot replicate the problem as I don't know what caused it in the first place. 4) The TV then started normally ( no reception as I had not aerial connected, etc.,) but I was able to gain access to the screen menu/setup buttons via the remote which were in French rather than English. However, after reconnecting everyrthing the TV has worked fine (obviously after resetting the language via the menu). I am sorry I cannot be more precise but I hope this might be of help to someone with a similar problem.
Posted on Dec 22, 2010
budmrtn
  • 11361 Answers
SOURCE: My toshiba 42rv530u standbuy orange
It can be bad power supply due to bad caps (domed tops), or it detects shorted circuits so it goes into shutdown mode. Inspect the power supply and the backlights inverters.
Please read my guides for more details.
Boards: http://www.shopjimmy.com/catalogsearch/result/?q=toshiba+42rv530u+
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps
Posted on Jan 19, 2011
SOURCE: Had my toshiba regza 42rv530u
try resting your tv. power off it press and hold av select botton and then power on your tv wait few minutes and it will rest your tv.... if not used the same wy holding menu botton instead.
Posted on May 30, 2011
I have a belkin wireless modem router model F7D1401 v1 and a week ago it would be normal then flash orange and stop working. however now it is a constant orange with the WPS button flashing orange.
I think you have the upper light blinking and lower light solid. Is that right? The upper light blinking means that the connection to your ISP is not working. Try unplugging/replugging the Ethernet cable in the top port (probably yellow and labeled "WAN" or "DSL" or something). Check the other end of that cable. If you have another Ethernet cable, try swapping it out.
If none of that works, call your ISP to check the connection.
Apr 05, 2015 | Belkin Computers & Internet
My 40" Toshiba LCD TV (model 40RV525U) won't turn on. While plugged in the green power light constantly blinks, but the TV won't power on. Unplugging the TV stops the power light from blinking, but once...
These blinks are fault indications, and are called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. If you're sound in electronics, this will make the repair easy. If you wish to get more details about these blinking codes, check this link. Blinking codes to many brand TVs are described in detail. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 06, 2013 | Toshiba 40RV525U 40 in. LCD TV
Orange light blinking when turned on and doesn't project picture
First check your manual for trouble shooting the lights meaning. I think it is the bulb.
Jan 10, 2013 | Toshiba TDP T1 Multimedia Projector
How to fix orange blinking light on ethernet
orange blinking on ethernet means that your connection is 10 Mbps and green blinking means 100 Mbps
there's nothing wrong with it
Aug 27, 2012 | Toshiba Satellite M35X-S163 Notebook
Time light blinks 3 times tv does not turn on is it the lamp? and if so how do i fix it
This tv is a LCD tv?Yes.No projection lamp on a LCD tv.Blinking LED any lights,LED light have power indication word on it?Yes,that power supply board it is dead and the causes.
May 31, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Had my toshiba regza 42rv530u since March 2009 a few days ago it cut off and will not come back on, the yellow light flashes at the bottom of the tv, 3 blinks pause 3 blinks etc....
May 30, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Hi,Iwas watching TV and the screen went black.No lights on,I unplugged and plugged again but anything happened. My TV is a Toshiba Regza model 42RV530U. Can you help me? Thanks
If there was a popping noise of any kind when the tv screen went black there's a high possibility that one of the fuses in the tv popped and there is no power to the tv. It could also just be the outlet itself and try plugging the tv to different working outlets.
May 24, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
42rv530u toshiba tv no sound no picture change power supply and main board
The 42RV530U is known to develop problems in both the power board and the main board. You can check out our power board repair service at
http://www.coppelltvrepair.com/p/442/repair-service-for-toshiba-42rv530u-power-board-75010942-dead-tv-or-clicking-on-and-off-problem
and I'd also recommend that you search for 42RV530U at http://blog.coppelltvrepair.com as we will eventually release an article on how to test the board.
Hope this helps.
Aug 12, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
No pic and no sound on toshiba regza was told the power board was out is this an expensive fix
Hope this helps.
Nov 04, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Oct 04, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Televison & Video Logo
57 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
