Epson stylus pro 9880 maintenance request 0040
5 Suggested Answers
rcw1962
  • 2571 Answers
SOURCE: Maintenance request 0040 is showing
If you ring epson, they will charge $456.15, i found this forum that may be of help http://www.minilabhelp.com/forum/Blah.pl?v-print/m-1119948275/
one answer posted is this
Please follow the following instructions precisely?.
1) POWER OFF
2) Hold down the ?Paper Source? button + ?Cut Eject? button + 1 paper feed button (Down arrow)
3) POWER ON, whilst holding the buttons.
4) ?View Counters? should appear on the display, so press ?Paper feed? button down until ?Clear Counters? is displayed.
5) Press ?Select type? button + Paper Feed button + wait until ?Cleaner? is displayed.
6) Press ?ENTER? button TWICE
7) Switch machine OFF
8) Switch machine ON
Outcome
The error display should then have disappeared, and should read READY
IMPORTANT
This process can ONLY be followed ONCE before an engineer is required.
Hope this is of help
Posted on Oct 27, 2010
caroldon
  • 17130 Answers
SOURCE: maintenance req 0040 on my
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Posted on Aug 09, 2011
Ezrahite
  • 2632 Answers
SOURCE: Epson Pro Stylus 9600 is
Welcome to Fixya.
Your error code req 0040 means the Pump/Cap/Cleaning assembly has reached the end of its life and will soon fail. This is a major replacement part and it is typically more cost effective to replace your printer rather than repair.
You can continue to print, but soon you will experience leaking ink, damaged hardware and poor prints.
Here is the solution for your prob. Turn Off your printer then press the Left, Down arrow and Enter simultaneously then power On the printer. inside initialize the sponge and cleaner then turn Off and On your printer.
You have to replace your pump cap assembly if it is already poor in cleaning otherwise your printhead will suffer.
Thanks for using Fixya.
Posted on Feb 15, 2011
  • 158 Answers
SOURCE: we have an EPSON STYLUS
The codes should be in the owners manual. Otherwise go to the web site in the support area. Type in the printer model then look for error codes support.
Posted on Mar 01, 2011
How to fix printer blurr
most likely you're wiper for the capping station is covered in ink. I recommend having the printer cleaned by someone who does maintenance on Epson printers.
Mar 21, 2014 | Epson 9880 stylus pro Printer
Maintenance 0040
download the adjustment program for epson 9880 & change the date & time
Dec 17, 2013 | Epson Stylus Pro 9800 InkJet Printer
Epson 9800 Cleaning Unit Replacement
you don't need to replace any thing just before on your printer press and hold Down, Right and enter buttons on printer panel and than on the printer after on leave the pressed buttons its show a new menu on it press down on adjustments and than enter again press down on counter clear and than enter again reset it than restart printer. thanx
Jan 08, 2013 | Epson Stylus Pro 9800 InkJet Printer
We have an EPSON STYLUS PRO 9600. We have received the msessage MAINTENANCE REQ 0040. Can you help us, please? Thank you very much.
Mar 01, 2011 | Epson Stylus Pro 9800 InkJet Printer
Maintenance request code:
The pump counter is near end of life, replace the cleaner kit ASAP.
This is what 0040 means.
May 03, 2010 | Epson Stylus Pro 9800 InkJet Printer
Maintenance request 0002
Epson
Maintenance request 0002What is this mean?
May 19, 2009 | Epson Stylus Pro 7800 InkJet Printer
3,398 people viewed this question
jasbo
jasbo
