Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Stopped running i was cruising earlier this week on my 2000 harley sportster 1200 and the speedometer was fluctuating and there was a slight miss when the speedometer dropped to 0. that happened for roughly 70 miles mainly when i was at a steady speed and then while i was riding the engine stopped running altogether. i checked and have gas getting to the carb, i also checked the wires, distributor, all fuses. don't know where to go from this point. thanks for your help
  • jeramiwood Oct 26, 2008
    battery is still turning over the bike and a motorcycle doesn't need a full battery to operate
  • jeramiwood Oct 30, 2008
    No i don't know how to check for that. i have a volt meter. what next?
  • 216 Answers
Whats an Alternator belt.> In a harley ? whatever
Do you know how to check for a grounded stator ? That can cause the erractic behaviour you describe. I can explain how if you need me to. You'll need a voltmeter.
Posted on Oct 30, 2008
  • Mel Jacobson
    Mel Jacobson Oct 30, 2008
    OK ... Its not hard... Turn off the ignition. Follow the regulator wires down to where it connects into the crankcase, disconnect it - there are 2 leads. Ther should be no continuity between those 2 sockets - ie- u should get no reading. I said voltmeter - but - u'll need an ohmmeter (sorry). you insert the leads into the socket with the meter set on the RX1 scale. Any reading indicates a grounded stator - and unfortunately = a pretty expensive repair. but with an 8 year old bike - not uncommon. If it passes, let me know ........ electrical problems can be a ***** to run down ... good luck
  • Mel Jacobson
    OPPS ..... easier way .......with the bike off ..... put the voltmeter on the battery terminals - + to+ and - to -
    u should get a reading around 12.5 or so ........ now - put it in neutral and with the motor running.... recheck your readings ..... it should increase to about 13.5 volts or more ....... if it goes down instead - u gotta charging problem , NOW - to the stator test
  • 41 Answers
Check your alternator. Or the Alternator belt.
Sounds like you basically used up the rest of your charge in the battery after the alternator went out.
let me know.
Posted on Oct 26, 2008
1993 Harley Sportster 1200 fuse box location
Hi, Cecil fuse and circuit breaker location are as follows:
SPORTSTER-Underneath the seat or behind the left side panel or inside the headlight bucket.
SOFTAIL-Underneath the seat behind the battery or under the speedometer housing.
DYNA-Behind the left side panel.
TOURING-Under speedometer housing or left and right side panel.
Under the speedometer housing or inside the headlight bucket location is for mechanical circuit breakers only.
The following is an approximate timeline of Circuit Breakers and Fuses.
1965-1990 circuit breakers only.
1990-2000 circuit breakers and fuses.
2000 and up fuses only.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
1993 Harley Sportster 1200 fuse box location Google Search
https://www.carlsalter.com/pdfs/Harley%20Davidson%20%20Sportster%201986-2003%20Service%20Manual.pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
Safety Recall Information Harley Davidson USA
Instant Tech Relief
Dec 02, 2017 | Harley Davidson XL 1200 C Sportster Custom...
1200 sportster C. after 18 klm. riding the speedometer cuts out signals wont self cancel bike runs good
Rob, some say its a speed sensor issue, clean or replace. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sportster Speedometer Problem Harley Davidson Forums
Speedometer auto cancel directionals stopped working Twin Forum Harley...
Speedo auto shut off for turn signal not working and wont idle
Jul 28, 2016 | 2005 Harley Davidson XL 1200 C Sportster...
Speedometer not working, got power but needle not moving on xl 1200 harley sporster
Hi Anonymous, check the wiring and connections from speedometer to the speed sensor. For a free wiring diagram please visit the website below:
Harley Davidson Wiring Diagrams and Schematics
Good luck
Feb 17, 2014 | 2000 Harley Davidson XL 1200 C Sportster...
My 1998 Harley sportster won't start but the speedometer get's power
Different fuse. Check the fuse block located just behind your battery. Just pull the cover off and slide out the main fuse block, the very bottom one is blown if the starter wont turn over.
Jun 10, 2012 | 2000 Harley Davidson XL 1200 C Sportster...
How much slack should the timing chain have on a 2000 Harley 1200 sportster?
Hi Mdougan_2, for more information about your question please visit the websites below. Good luck and have nice day.
Delboy Garage How to Harley Sportster Primary Chain Adjustment
May 14, 2012 | 2000 Harley Davidson XL 1200 S Sportster...
2000 Harley Sportster 1200S has no spark
Hi Mike, please be aware that this question has already been asked and answered. Thank you.
Apr 15, 2012 | 2000 Harley Davidson XL 1200 S Sportster...
How do I fix my stuck needle in speedometer on a 96 Harley sportster 1200
The speedometer is not repairable. You simply replace it. There are places that specialize in "restorations" of speedometers but they mostly work on original equipment speedometers for collector's grade restorations and are VERY expensive. It's cheaper to simply replace the speedo. You may want to record the mileage on the bike and you'll probably have to note on the title that the mileage shown on the new speedo is not correct when you sell the bike.
Good Luck
Steve
Jul 23, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
2000 XL 1200 S Sportster Sport: 2003 Harley 883 Sportster Hugger sat for a year. D...
Remove the carb soak in carb cleaner, **** out small bleed holes with a wire from a wire brush etc. One of the passageways is still clogged, or the float is sticking.
May 17, 2010 | 2000 Harley Davidson XL 1200 S Sportster...
Sportster sport sppedometer problem
replace TSSM this module uses speed sensor to trigger cancel.
Apr 02, 2009 | 2000 Harley Davidson XL 1200 S Sportster...
Lands Phones Logo
166 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
