Question about Franke PF3000 Deck Mounted Pot Filler Faucet with Two Valves: Polished ....
Grohe pot filler
Why does it say to install to cold water only. My husband connected to our grohe pot filler to the hot water supply as he never follows instructions, and I was shocked to get hot water! Will this be a problem?
    Scholar:
  • 50 Answers
Here is the link to the install manual for your pot filler... http://www.frankeksd.com/grfx/pdf_files/installs/PF3000.pdf
It mentions 'cold water only' in several places, but also mentions maximum hot water temp of 175, which is hotter than most hot water heaters (140-150), so I don't think (without being an authorized factory rep) that your hot water temp will hurt it... keep on keepin on... always wanted one of these for myself...
Posted on Jan 05, 2009
I want rotate my Grohe ladylux kitchen faucet. The handle is on the left and I want to rotate to the right side. How do I do it? Thank you John
You will presumably be pushing the faucet handle away from you instead of pulling it forward? If you don't like it, you can always put it back.
Turn off the water.
Release the water in the faucet. If you have a faucet in a room on a floor below, open that to drain the water.
From underneath the unit, back off the nut that is gripping the worktop. Slacken off the hot and cold supply pipes. I am hoping you have braided flexible hoses, or you can't do this job very easily.
Spin the faucet 180'.
Retighten the hold and cold supply pipes.
Retighten the holding nut.
Turn on the water and open the faucet.
Check for leaks.
There is an installation video here.
https://www.youtube.com/watch?v=sQgi0CMAxYM
and some further information and diagrams here.
Removing Grohe LadyLux Caf 33 755 Faucet Handle
Jan 02, 2016 | Grohe Plumbing
How to replace the stainless steel braded supply hoses for the hot and cold on a kitche faucet grohr
shut off water supply knobs remove hoses with pipe or crescent wrench at the base of the faucet under the sink and knob connections
Jun 28, 2012 | Grohe Home
I have a Grohe 32362 AVO bath faucet that began to show signs of slow water flow (both hot and cold). I turned the water supply valves off and then full "on" and then water flow ceased entirely? The...
hi, the fault is probably from a tempering valve, on the inlets (hot and cold feeds to the tempering valve) there are little filters that block up easily undo the connections to the tempering valve remove the filters and clean them
Jun 12, 2010 | Grohe Chiara Neu Lavatory Centerset ...
Grohe ladylux cafe faucet has low flow eventhough supply valves are wide open. This is true for both hot and cold. When supply is disconected from faucet and valve turned on there is ample pressure. Is...
I have the same problem and have the fix. There is a water pressure regulator on the bottom of the faucet( under the sink) this part is bad. Grohe will replace it for free. Call Grohe at630=582=7722 tell them the model # of the faucet and the color of the regulator, they will send you a new one for FREE.
Jun 09, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
How to install supply lines for Grohe k4 faucet
I hope this helps.
Step11Turn off the water supply. You'll find a shut-off valve under your kitchen sinkmag-glass_10x10.gif. Once the water is turned off, open up the kitchen faucets to allow the water remaining in the pipes to drain way. Step2Catch the drips by placing a bucket under the hot water supply line, located on the left side of your sink. Even a minimum of water can cause a mess and be potentially damaging. Step3Use a wrench to remove the compression nut that secures the hot water supply line. Let the disconnected section fall into the bucket. Use the wrench to loosen and remove the nut at the other end of the line and remove it as well. Step4Repeat Steps 2 and 3 for the cold water supply line. Step5Replace the cold water supply line. Hand-tighten the nuts on both ends, then use the wrench to tighten the nuts completely. Repeat the process with the hot water supply line. Step6Turn on the water supply and test for leaks
Apr 08, 2009 | Grohe 32.074.KD0 K4 Prep Sink Single-Spray...
Hot water pressure is fine, cold water is low.
You may have debris caught in the supply line or the mixing valve. You will need to take the unit apart after you have turned the water off and inspect those parts. Also, some of the new faucets have cut off valves already installed on the faucet, if you do make sure that they are fully open as well.
Mar 31, 2009 | Grohe Plumbing
No water pressure from Grohe faucet when changed the sink
No, being reversed wouldn't cause it. The only thing that would happen is the direction you turn your handle to get the desired temp. When you remove fittings from plumbing supplies, you can break loose deposits that can clog the faucet. If both the hot and the cold water is affected, then remove the arriator and rinse it clean. That is the little filter looking devise at the end of the spout. But if only one of the supplies are affected (hot or cold) then something has broken loose and is stuck within the valve and needs to be cleaned out. You should take the arriator apart piece by piece making sure to note the order in which you take it apart so it's put back in the right order.
Mar 22, 2009 | Grohe Plumbing
Franke PF3000 Deck Mounted Pot Filler Faucet with Two Valves: Polished .... Logo
283 people viewed this question
Top Franke Plumbing Experts
ray gallant
William Wurtinger
David Ellis Rhea
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
