Question about Dayton Heating & Cooling
Dayton portable heater 3VE51A manual
I need 3VE51A manual.
5 Suggested Answers
  • 188 Answers
SOURCE: Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
Posted on Jun 30, 2009
  • 188 Answers
SOURCE: manual for a 3ve51 dayton heater
Check under construction heaters online www.desatech.com. They should have what you are looking for. Thank you
Posted on Jan 28, 2010
  • 1015 Answers
SOURCE: Need parts for Dayton Ultra Portable Heater Model
I would cotact Grainger industrials supplies by callig 1-800-323-0620. Or e-mail at Grainger.com I have dealt with this company for 25 years and I've always been happy to do business with them. Hope this helps you. You will need name brand,part description,and part no. if possible.
Posted on Nov 18, 2010
SOURCE: Dayton 3VE59 Gas Utility/Portable Heater won't
Just repaired one of these, problem was that main gas valve was not opening, valve is controlled by a vacuum switch, vacuum is created as fan blows air down tube past bent up metal flap near front bottom of heater (slight low pressure zone created). If vacuum switch is miss adjusted it will not close when fan is running and no gas flows. this is easy to check as vacuum switch also has a pressure port on it. With gas disconnected, remove bottom cover, locate vacuum switch (it has a hose clear plastic hose connected to it, in opposite corner is another hose connection, attach a length of hose to it that you can blow lightly into. With heater plugged in and no gas connected (USE CAUTION OF WIRE!!!), turn heater on you should hear after a few seconds the ignition and then a loud click as the gas valve opens, if no click blow lightly into end of your added tube, if you now hear a click the gas valve just opened. if you stop blowing you might hear the gas valve click again as it re-closes. If this is the case the vacuum switch needs to be adjusted slightly. THIS switch is hear for your safety, Adjust at your own risk!!! This can be done with a screw drive in the top, rotate screw slightly while checking if the fan alone causes enough vacuum to make the switch work. DO NOT over adjust. check safety operation before hooking up gas by placing a piece of cardboard or wood over the air intake and the exhaust to block airflow, if the air flow is blocked you should hear the gas valve drop out and reconnect as air flow is reestablished. Hope this helps
Posted on Feb 13, 2011
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Need a manual for a Dayton Model 2YU40 electric heater
Contact Grainger
http://www.grainger.com/product/DAYTON-Convection-Ceiling-Heater-2YU40
Grainger owns Dayton manufacturing
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 05, 2014 | Water Heaters
What is correct pump pressure model 3ve51b dayton heater
Go to http://www.bealsmotor.com/heathogprices.html you will find a bunch of models, click on the 3VE51A as the settings will be the same as the 3VE51B. The parts will be the same also.
Dec 08, 2011 | Dayton E50 Heater
I need ignitors for heater model number 3e219e
The part number for the ignitor kit is PP200 (new number) Old number was PN HA 1000.
Also from the parts list, this PN: 102548-03
Parts list:
http://www.bealsmotor.com/105553_219E.html
Burner head parts: (Ignitor is item 5)
http://www.bealsmotor.com/105553_burner.html
Actual Ignitor Kit:
http://www.amazon.com/Desa-International-Hot-Surface-Ignitor/dp/B000DZDPVI $39.95 + shipping
Downloadable manual: http://www.desatech.com/manuals/Construction%20Heaters/105553-01.pdf
Dayton Portable
Oil-Fired Heaters
PARTS:
Ph. 1-800-323-0620
24 hrs / 365 days a year
105553
2E510F, 2E511F, 3E218E, 3E219E
Please provide following information:
-Model number
-Serial number (if any)
-Part description and number as shown in parts list
102548-03 (part you need)
Thanks for choosing FixYa,
Kelly
Nov 19, 2010 | Dayton Heating & Cooling
Need parts for Dayton Ultra Portable Heater Model 1VNX6A I need a source for parts
Nov 18, 2010 | Dayton E48 Oil Filled Utility Heater
I need a service manual for a Dayton oil fired 350,000 BTU heater.
I have a manual for a Dayton 3E218E. If you want a copy email me at Edwards0202@aol.com and put "HEATER MANUAL" in the subject line. I can scan it in and email it back to you. This manual is for 2E510F, 2E511F, 3E218E and 3E219E. I also found a great web site for parts for all these models as well:
Nov 30, 2009 | Dayton E50 Heater
May 04, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a Dayton E48 heater that is in disrepair
portable heater parts.they have an on line service and parts. www.portableheater.com
Jan 30, 2009 | Dayton E48 Oil Filled Utility Heater
Heating & Cooling Logo
185 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
