Question about Lisle Oxygen Sensor Remover for Use with Air Hammer/Chisel
How do u replace an oxygen sensor on a 95 dodge avenger?
Just bought a 95 avenger and the check engine light was on and had it checked at my local auto zone. code came back as a bad oxygen sensor. dont know how hard it would be to get to to change it, or if there things i would have to remove from the car to get to the old sensor to replace. anyone with comments or feed back would be appriciated?
    Problem Solver:
  • 3 Answers
It is on your intake system, should be visible close to your air filter, it is simple to replace, just pop the old one off, and replace with the new one, I'm not sure on that specific model where it is located but it IS on the intake. It is fairly simple to replace. If you have any problems, or questions lmk.
Posted on Feb 17, 2012
My Dodge Stratus (1998 4 cyl) check Engine light is on. The error code says oxygen sensors were bad. Both oxygen sensors have been replaced. After resetting the check Eng light. The oxygen sensor
the upper 02 sensor is for air fuel mix while the secondary 02 sensor is for the operation and status of the catalitic converter are you sure the catalitic converter is not plugged. Could be if you have had a loss of power
Sep 16, 2014 | 1998 Dodge Stratus
Installed new oxygen sensors but light is still on
You need to clear the check engine light with a scanner. If you clear it and light comes back on check for a new code number. If you bought your parts locally the parts store should scan/clear your codes for free.
Mar 01, 2014 | 2001 Chevrolet Silverado 1500
I have a 2000 Dodge Avenger. The check engine light came on as soon as I hit 90,000 miles. A friend said they are set to do that and that it can be reset. The car seems to be running fine. Is the check...
If you take it to a auto parts store they can help you get the code out of your cars computer. This will not cost you anything and may help identify the probelm. I use Autozone and Carquest for my parts stores.
Jul 13, 2009 | 2000 Dodge Avenger
Transmission codes:
I WOULD TRY REPLACING THE INPUT SPEED SENSOR..A DEFECTIVE SPEED SENSOR CAN CAUSE ALL OF THESE FAULTS..IT IS LOCATED IN FRONT OF TRANS ABOVE SOLENOID PACK..IT IS THE ONE CLOSEST TO THE ENGINE..IT SCREWS INTO TO TRANSMISSION..A 1 INCH SOCKET FITS IT..ALSO CHECK WIRING TO BOTH SPEED SENSORS..A SENSOR IS ABOUT 35 BUCKS,AVAILABLE AT YOUR LOCAL DODGE DEALER..GET A NEW ONE AND YOU'LL SEE WHAT IT LOOKS LIKE..FAIRLY COMMON PROBLEM..HAVE REPLACED LOTS OF THEM
Jul 06, 2009 | 1999 Dodge Avenger
O2 sensor
are you sure that it is still the O2 censor? are you assuming because the check engine light is still on? because you have to reset it after fixing something you just disconnect your battery completely for a bit like 15mins and then reconnect it and the light should go away.
Apr 15, 2009 | 1997 Dodge Avenger
Idle problems with my 95' avenger
you may have a bad engine coolant temp sensor. that is what frequently causes that issue on dodges
Apr 13, 2009 | 1995 Dodge Avenger
1995 Dodge Avenger 2.0 engine bogging
i think your on the right path with wires and plugs. also has your timing belt ever been replaced. if is a little lose it could be retarding the valve timing.
Mar 15, 2009 | 1995 Dodge Avenger
My Check Engine Light keeps coming on
check your MAF sensor, if it's dirty clean it then reset your check engine light again. this should work.
Feb 19, 2009 | 1999 Chevrolet S-10 Pickup
Oxygen sensor
Yes, its the oxygen sensors. install what you bought.
Jun 17, 2008 | 2002 Ford Ranger Regular Cab
Check engine codes 95 dodge intrepid
Code 12 is: Direct battery input to PCM was disconnected within the last 50 key-on cycles.
Code 21 is: Neither rich nor lean condition detected from the oxygen sensor input or oxygen sensor input voltage maintained above the normal operating range.
May 22, 2008 | 1995 Dodge Intrepid
Lisle  Oxygen Sensor Remover for Use with Air Hammer/Chisel Logo
245 people viewed this question
Top Lisle Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Lisle Air Tool and Compressor Expert? Answer questions, earn points and help others
