Question about Garden
Toro GTS 6.5 HP doesn't run well in grass. Any ideas?
I have a Toro GTS 6.5 HP with a Tecumseh engine. It starts easily and runs for as long as I keep it on the driveway. It only runs for about 5 minutes in the grass. It has a new spark plug, clean carburetor and jets, new air filter and recent oil change. The lawn is well maintained and should be an easy cut. Any ideas?
  • 1 more comment
  • Rose Carncross Feb 17, 2012
    It has new gas.
    I do not find a fuel filter. The fuel line is only about 3 or 4 inches long and goes directly from the bottom of the gas tank to the carbutetor. The spark plug seems to be working well.
  • Rose Carncross Feb 20, 2012
    Any other ideas?
Has the fuel filter been replaced lately? Also you can look to see if the new spark plugs are getting fouled out still. Sometimes just replacing the spark plugs wont fix the problem.
Posted on Feb 17, 2012
2strokeJim
  • 577 Answers
SOURCE: Toro GTS 20332 (bought it 12 months ago) won't run
I believe that Toro Guarantees to start 1 Pull, was gas left in it all winter?, If so this is'nt covered under warranty, cause gas is to be ran out or dumped out at end of season this will prevent any gumming up of carb . did you completely disassemble carb? does it have a primer on it, those gskts need replacing, clean out the jet in bottum of float bowl,small holes,sometimes missed and remove and check your needle/seat to make sure that when float drops gas runs out then lift float up and gas should stop. hope this helped you,another thing spray carb cleaner in carb and pull over and see if it will start that way enough to keep running with choke to see if it will **** gas into it
Posted on May 16, 2011
SOURCE: carburetor linkages for riding lawn mower
Go to a tecumseh website and get a breakdown of the parts list and that should help a bit. Good luck.
Posted on Mar 26, 2009
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
  • 376 Answers
SOURCE: no gas to carb on toro gts
Carb needs to be cleaned/repaired. Without knowing model number of the engine, that's all the info I can give you.
Posted on Jun 20, 2009
rycgl
  • 1545 Answers
SOURCE: i need the correct way to connect the governor
this may not apply exactly to your particular model, but it is for Tecumsehs and may get you on the right track:
http://www.angelfire.com/mb2/visitme/mower/tecumseh.html
Posted on Jul 13, 2010
Changed filter, oil, full of gas checked gas flow everything is good , when I start m lawn mower it runs , when I engage my pto and start mowing for about 5 minutes it just quits
if this is got the 27 hp kohler engine, I know exactly whats wrong with it , due to grass and engine oil building up in a short time under cylinder heads , it actually makes a tight ball of grass and stuff there !! this holds the engine heat and ruins the ign module that's just above it there , I put two on in one season ( tractor runs 6-10 hrs day 6 days a week ) I finally gave up I bought a Kawasaki 27 hp twin and installed it , now its run for two seasons and no problems
engaging the pto has nothing to do with it , it would cut off if you just drove it around for 15 minutes
Sep 15, 2015 | Toro 52" 27hp Z Master Zero Turn Lawn...
I own a Toro model 20070 mower with a Tecumseh engine. It's 8 yrs old. I have regular maintenance conducted. The mower starts and runs well but about 20 minutes into mowing, when I shut it down to empty...
Are you sure there is oil in the machine?
Are the Fins on the engine clean and not loaded up with sand and mud?
Sounds like it is running so hot that it is seizing.
Aug 06, 2014 | Toro Garden
May 16, 2011 | Toro Garden
Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Mar 03, 2010 | Garden
No torque/hp when cutting a patch of grass.
SOUND LIKE THE NEEDLE OR FLOAT IS BAD IN THE CARB. I SUGGEST GETTING CARB REBUILD IT DOES COST THAt MUCH.
Jul 17, 2009 | Toro Lawn Mower With Toro Power Tools
I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
428 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
