Question about Hampton Bay B52852WPB Redington III White and Brass Ceiling Fan
Lights are now dim.......
I installed a ceiling fan about 2 months ago. I also installed one of your remotes for the fan. Then the other day the lights started only getting half power. The fan has full power, and the other items using the same electrical are fine. I can not figure out why the lights are dim now. The fan only has one switch for the lights, either on or off. If you can help me solve this problem I would appreciate it. Thank you in advance.
    Scholar:
  • 48 Answers
Aside from a wiring fault upon installation that may be creating a small short, or interference from the fan motor, have you tried fixing the cheap parts? I.E. changing the lightbulbs out for a different set, or different types? Try using flourescent bulbs in place of your normal incandescent bulbs. Also, what wattage are you using? Your fan unit may have a limitation on wattage, or may only be throughputting a certain wattage due to a wiring problem. Does your fan have an energy saver setting?
Posted on Jun 04, 2007
The back of my Turn of the Century fan's remote control has this switch in the back of the battery housing. It's marked with 'D' and 'CFL' on either end. Can someone tell me what this switch means?
The switch is allows you to tell the remote which type of light bulb you have installed in the fixture. The CFL setting is for the included compact fluorescent bulbs. With these bulbs, you can only turn them on and off. If you put in incandescent bulbs, set the remote to D. Then you can dim the lights in the ceiling fan, in addition to turning them on and off with the remote. CFL bulbs can't be dimmed with this fixture.
I found this described in the manual for the Turn of the Century Midori 52" ceiling fan. This fan is available at Menards: https://www.menards.com/main/lighting-ceiling-fans/ceiling-fans/indoor-ceiling-fans/turn-of-the-century-reg-midori-52-contemporary-ceiling-fan/20338/p-1444433460319.htm . The direct link to the manual is currently https://hw.menardc.com/main/items/media/HONGK003/Install_Instruct/3551058-3551059_install.pdf .
I hope this helps.
Apr 01, 2018 | Dryers
Help. I need help properly connecting wires on a new ceiling fan.
Usually, the fans with remotes will dim the lights by holding the light button for a few seconds. So, the red wire would stop this feature if wired directly to the fixture. That would eliminate the wire coming out of the receiver for the lights. If you want the light to dim, then tape off the red wire, so the remote will dim them. The wall switch won't work anymore. If you want to connect the red wire , tape off the wire from the receiver that connects to the light sockets and connect the red wire to the wire for the light sockets. This will operate the fan but the remote will not dim the lights. If you have a motor speed controller in the wall from the old fan, remove it and replace it with a switch or eliminate the switch altogether so the remote will control the fan speed.
Nov 13, 2016 | Dryers
How to use remote on ceiling fan id m8crl 103
Press the light button and bottom green button at the same time the lights dimming feature will work!
Mar 09, 2012 | Hunter Designer's Choice 5-Switchblades Lg...
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
Flickering lights
make sure you have the remotes/receivers set to different jumpers. I installed 2 fans and had the same problem, just had to change the jumpers on one of the fans and the corresponding remote
Jul 19, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Apr 01, 2009 | Hunter 52" Ceiling Fan With Light And...
Harbor breeze ceiling fan
Your voltage is probably too low, probably a bad wire or source. Let me know if it worked.
Or take a look at the link given here... http://www.ceiling-fan-wizard.com/harbor-breeze-ceiling-fans.html
Aug 03, 2008 | Dryers
Hampton Bay B52852WPB Redington III White and Brass Ceiling Fan Logo
195 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
