Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore model7957160 error code erff
Had been making a loud fan type sound then coded
  • Kenmore Master
  • 4,654 Answers
ER FF is a Error Message that your Freezer Fan is not working properly, W10128551 Evaporator Fan Motor The problem could be your=> 2169142 Fan Blade has become damaged either by ice or loose fan motor mounts. Someone will need to unplug and remove the rear panel of freezer to observe just what has taken place, Thanks Sea Breeze
Posted on Feb 18, 2012
Er ff
You need to remove the freezer door and basket. then remove the rails on both sides. then there is a panel at the back of the freezer. Pull at the top part of the panel and it will come out.
Feb 07, 2014 | LG LFX21980ST Stainless Steel Bottom...
Kenmore error codes
This code means Evaporator Fan failure, look at the evaporator fan in the freezer for issues, this should also have issues with refer temps too when the fan has an issue.
Good Luck
Dec 22, 2013 | Kenmore 23.1 cu. ft. Side-By-Side Counter...
Will not drain. Getting error code F02
yes exactly.you are right.its the pump problem. F/02 error code:-- Long DrainIf the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
try this :-- Press PAUSE/CANCEL twice to clear the display.
:Check the drain hose and make sure it is not plugged or kinked.
: Check the electrical connections at the pump and make sure the pump is running.
: Check the drain pump filter for foreign objects.
: If the above does not correct the problem, replace the pump.
you can get required parts from www.repairclinic.com
Nov 27, 2009 | Kenmore Washing Machines
Kenmore Elite trio Error 15
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Refrigerator Trio display panel read ER IF and everything seems to be melting or thawing. Not making ice and water is running from door where the ice seems to be melting? HELP! My freezer...
Jun 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
F 61 Code
The if the "bad sound" is coming from the speaker(s) it probably needs the output ic. If it is coming from the player itself check that the fans are working. F61 is an amp error code but a non-rotating or unplugged fan will also set it off.
Feb 09, 2009 | Panasonic SC-HT920 System
Fridge not working
Error code ER FF and evaporator fan makes loud noise
Aug 15, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore He3Washer Fills then gives error code
remove lower panel right side underneath tech manual with codes
Jul 04, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
103 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
