Question about Quasar VV2009 Combo
Quasar model VV2008 tv/vcr
It only displays "line" and channel 5 when I use the channel selector on the set. I don't have the remote; is there another way to change the channels? I want the connect it to a converter box that requires channel 3.
Any help would be greatly appreciated.
Thanks,
James
  • jamesiw Oct 27, 2008
    I'm assuming you mean inside the set; I have to admit I'm not too up on tv's; but I do build and upgrade computers. Again I'm assuming the turner is on the main board and can be manually set to channels as jumpers or switches are on a CPU motherboard.
    Thanks,
    James
Make sure it is on the tv channel (5) in your case, then hold down play and FF buttons at same time for 5 seconds or so. TV will turn off. When it comes back on screen will show auto program screen, push the channel up button and you will be set. I bought a 6 dollar RCA grey remote at the Family Dollar store, pushed code search then VCR button and code 0162 then enter button. Remote works just fine.
Posted on Apr 19, 2013
  • 23 Answers
In side the mother board(kit)  there should be vertical IC gone.   check the vertical section  for  the IC number  and  replace it  ,     this  will solve ur problem
thanks
Posted on Oct 26, 2008
  • Nagarjuna Chary
    Nagarjuna Chary Nov 04, 2008
    ok i got ur problem.
     u cant do , so it is  better to show ur tv to any technician   ,
    i am thinking that inside  vertical ic gone , and  that should be replaced by same number,then only  u will  get channels   and   u can connect it to a converter box that  requires channel 3.
     tv works as usual........
    the major problem is  there is no vertical signal  to vertical deflection coil..........ok
    thanks .........
I HAVE A QUASAR VV2008 TV/VCR COMBO AND I DONT HAVE REMOTE AND CANT GET TO NO CHANNELS EXCEPT 60 AND LINE
The remote model number for the Quasar VV2008 is VSQS1570 and can be ordered from Panasonic at 1-800-221-7262 or Go to a Family Dollar store and purchase the grey RCA universal remote for $6.00 about 6 inches in length. When you are ready to program it for the Quasar VV2008 push the code search button then the VCR button and enter 0162 then push enter. The red light should go off and the remote should turn the TV/VCR off and on. It worked for me 4/19/2013
Apr 12, 2011 | Quasar VV-2002 20 in. TV/VCR Combo
Auto program channels manually
the only way is with the original remote for the set.
Aug 07, 2009 | Quasar SP-2722 27" TV
I have a vv2008 tv/vcr combo. I have sound, no picture, but do have a display. It seems as thought it is in French, The remote has been lost, and I have an rca universal remote that changes channels,...
buy the correct remote for this model#.go to
encompass.com and go to guest login.put in your model#vv2008 and will list your remote in
the parts list.
Jul 17, 2009 | Televison & Video
Quasar tv remote.
Sounds like you need to go to the main menu and run the automatic channel selector again. It will take note note of which channels are not in use and then skip over them when you use the channel advance. Use your remote to get into the main menu and select the "TV" submenu. Then run the auto channel select. After that's done, you can also manually choose to skip channels you don't like. I believe the channel numbers appear in green if they're to be included, and yellow if they're to be skipped. Even if a channel is skipped, you should be able to get to it anytime by punching in the number on your remote.
Jul 08, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Set up for cable
You might be able to restore the factory settings by pressing "play" and "FF" simultaneously and hoding them down until the set shuts off (about 5 seconds). Then when you turn it back on it will lead you through the setup routine, which includes auto channel select.
Plan B would be to buy a universal remote.
Jun 26, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
NEED REMOTE CONTROL #VDQD-1570 FOR QUASAR TV MODEL VV2008
Found one at Mr Remote.com They have everything.
Jun 21, 2008 | Televison & Video
Use of tv channel 3 or 4
You either have to choose either 3 or 4 or - instead of connecting to your TV through its tuner, go directly to the Audio/Video inputs using A/V cable (also known as RCA cable - probably has red, white, and yellow ends) Connect it from the color coded outputs on the VCR to the similar inputs on the TV. The TV may have several sets to choose from. Take you choice, but set the TV's input selector to this same designation when you want to watch the VCR. Sometimes its is called "VIDEO" sometimes A/V, sometimes "AUX"
Nov 28, 2007 | Quasar VHQ401 VHS VCR
VCR model VHQ 41m
I have not heard of one that doesn't have the selector switch to change to 3 or 4, Could it perhaps be in the front behind a door or just somewhere else?
Aug 01, 2007 | Quasar VHQ401 VHS VCR
How to UNDO autoset (channel setter)?
If I am not mistaking this is the same set as the panasonic PV-c2020. I attached an owners manual link here this should help you. Good Luck. http://service.us.panasonic.com/OPERMANPDF/PVC2020.pdf
Mar 16, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
Televison & Video Logo
444 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
