Question about Toshiba 32A60 32" TV
TV problem My Toshiba model 32AX60 keeps blanking out. I still have good sound and I know the inputs from the satellite dish are all correct including the inputs to the home theater system. There's a red light that flashes and when I tap on the front of the TV near the light after the screen blanks out the picture returns. The TV is about 12 years old and my wife insists that there is a component that is worn out and all of these types of Toshiba TVs experience this problem. I'm an old tech and can read schematic diagrams. If someone knows the problem and can send me schematics for this particular model I may be able to repair it myself. Thanks in advance for any help.
  • tyrmor Nov 08, 2008
    I have a toshiba 32A42A.When I try to power the TV on, All I hear is a clicking sound and a blinking red light at the sensor/power
  • 3130 Answers
SOURCE: Yet another Black screen issue
This manual is avail as a download at The first thing I would check would be the STR regulator IC in the main power supply, that is if the standby supply is good.
Posted on Sep 08, 2006
  • 1067 Answers
SOURCE: my toshiba wont turn on but red light come on an green light flashing no picture or sounds
yes ill got remote link for u here give me one sec
Posted on Jan 29, 2008
  • 1694 Answers
SOURCE: Picture went off then Red light blinks all the time
Not an easy fix....requires chassis pull, careful soldering and
replacement of parts and fuses.....would you like step-by-step?
Posted on Feb 01, 2008
  • 8617 Answers
SOURCE: Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Posted on Mar 02, 2008
SOURCE: Schematic Diagram
i need all the names of the components use in a tv schematic or on it board.
Posted on Oct 13, 2008
Autosetup on my DVB is not picking up stations. The TV is connected directly to the satellite dish and has all free sat stations. As far as I can see all the connections between the TV and DVB are as
I'm wondering where in the mix is your satellite receiver? The recorders currently on the market aren't able to decode digital satellite signals. They are capable of decoding cable but i'm unaware of any that work on satellite.
Sep 17, 2014 | Panasonic Televison & Video
The volume on my Toshiba CT-852 TV will not work with dish satellite but will work with DVD player
It is not the TV----How are you hooked up from the Satellite and what other inputs does the set have other than the coax or cable fitting?
Mar 13, 2012 | Toshiba Televison & Video
Sd dish reciever not recognized by hdtv tuner
Hey dgrines81!
I would need more information to provide an accurate solution including what model of receiver, but it sounds like you have an SD receiver hooked up to a HD TV.
Our SD receivers can show picture on an HD TV, they just need the correct cable. If your TV has the spot, I would recommend using RCA (Red, Yellow, White) cables. Plug those in to the receiver and the TV and then change the input. If the problem continues feel free to reach me here, or at
Tommy Faust
DISH Social Media Representative
Feb 12, 2012 | DISH Network 311 DTV Receiver
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Dec 29, 2010 | Televison & Video
Connecting Toshiba Satellite A105-S2071 to TV with S-video/RCA
after hooking the pc to the tv make sure the tv is set to the correct input, hit alt+f5.
Aug 06, 2009 | Toshiba Satellite A205-S4617 Notebook
Switch Toshiba projection tv to receive input from video-1?
If your DISH remote is programmed to your Toshiba TV, you can press the TV button at the top left of the remote and then release. This will put the remote in TV mode. Press and release the TV/Video button just below the clear TV button. This will cycle through the inputs on your TV. Continue to press and release until you have Video-1 displayed on your TV screen. I hope this helps.
Ray Calo
DISH Network
Jun 14, 2009 | DISH Network DVR-625 DTV Receiver /...
Need to know how to hook up 32' HDTV with DishTV satellite hookup
It seem that you maybe mistype the model number , take a look there this tv seems to fit yours , if not look at the other one and go in resources , there you can download the manual for your television , i own a toshiba lcd too and its pretty easy to plug i just plug it behind , use to remote input buttom and that it , just make sure you plugged the satellite dish cable at the good place behind your satellite receiver maybe it could be the problem too .
Jan 25, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
I just bought the 52 inch philips lcd tv model number 52pfl3603d. I'm trying to hook it up to my philips surround sound model hts3544 so I can hear the tv thru the surround sound. Watching a dvd is no...
Is the volume on the dish network device turned all of the way dowm?
Is the dish network connected to its pwn input on the SS system and did you turn the SS system to that input ?
Are you using the analog input (red and white) cables to the input from the TV to the SS System?, not from the SS box? This is not the correct setup?
Sep 25, 2008 | Philips Audio Players & Recorders
RCA Scenium HDLP 50
Jan 06, 2008 | Televison & Video
Toshiba 36a41 television
You should be able to use your remote control to do this.Your channel 73 is more than likely UHF 73 so you need to put your tv in the antenna setting rather than cable setting. Once you do this just input 73 with your remote. Hope this helps! Stargazer
Jan 21, 2007 | Sony KV-36XBR250 TV
Toshiba 32A60 32" TV Logo
76 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
