Hello
I have found the user guides for your printer, just download the user manual from here:
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/doc/manual_index.html?reg=eu&c=gb&lang=en&prod=dcp135c_eu_as&dlid=&flang=English&type2=-1
Hope this helps.
SOURCE: Can't install DCP-135C drivers WinXP
Normal
0
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: UNABLE TO INSTALL MY BROTHER DCP-135C PRINTER/COPIER
Hi!
Please open this link and select the model no. of your printer from there and then it will open up a new window from where you have to choose the drivers you want to install.
Link For drivers.
Do rate the solution
Thanks
Rylee
SOURCE: DCP 135C won't print in black
This is a generic problem for many printers. Some printers print black by 4 catridges. Try this, or it will be better that you call service support.
SOURCE: I have a brother DCP-135c printer. the magenta ink not printing
The process to get to the print head will take you approx. 1 hour. Without being trained on it, there is a high failure rate upon completion.
The Scanner assembly needs to be taken off. Harness Cables for the Scanner need to be removed.The Upper Case Assembly needs to be taken off. Printhead casing and printhead tubing calbes need to be removed, printhead mainboard needs to be removed, and then you have access to the printhead.
Thanks
SOURCE: BROTHER PRINTER DCP-135C INSTALLATION
i got disk if u want i can uplod disk and u can download
