Question about Dell 924 All-in-One InkJet Printer
Missing lines of print
When printing a doc some complete lines are missing
  • 3 more comments
  • Robert Caldwell Feb 22, 2012
    Don't think it's the cartrages as it will print a web page ok. It seems to be Word docs that cause the problem. I even have two pages of one doc, one will print ok the other won't.
  • Fabio Feb 24, 2012
    Have you checked the page setup section and made sure the page is set correctly also use the print preview option to make sure the document looks fine before printing.It could be that you are using symbols that the printer is not recognising.
    If you make a new document in word does it print fine ?
  • Robert Caldwell Feb 27, 2012
    I've checked the page set up and think it's ok, perhaps you could give me some pointers here. The print preveiw looks fine, everythings there. I've just tried a new word doc and the same problem is ocuring, half lines missing horizontaly, seems to be the tops of the text.
  • Fabio Feb 28, 2012
    What version of word are you using?
    Try changing the margins as described in this article:http://word.mvps.org/faqs/formatting/bot...
  • Robert Caldwell Mar 07, 2012
    Hi, I'm using Word 2003, I've tried changing the margines around but no joy. Some of my old docs still work fine but new ones have this problem. To print a letter the other day I deleted the text on an old doc that is ok and re-wrote my new letter, it worked fine.
  • 400 Answers
Hello
You either have to change the ink cartridge or try to clean the ink cartridge nozzles as described in the user manual;
http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
On page 54 it states the following:
To clean the ink cartridge nozzles:
1 Load plain paper. For more information, see "Loading Paper" on page 19.
2 In Windows XP, click Start-Control Panel-Printers and Other Hardware-Printers and
Faxes.
In Windows 2000, click Start-Settings-Printers.
3 Right-click the Dell Photo AIO Printer 924 icon.
4 Click Printing Preferences.
The Printing Preferences dialog box opens.
5 Click the Maintenance tab.
6 Click Clean Print Cartridges.
7 If the print quality has not improved, click Print Again.
8 Print your document again to verify the improved print quality.
9 If you are not satisfied with the print quality, wipe the ink cartridge nozzles, and then print
your document again.
hope this helps.
Posted on Feb 17, 2012
Canon Printer - Pixma 5000 Trying to print out pages of text. The text is coming out with a line printing normally - then a block of text / lines missing completely - then tops of line or bottom of line...
pull out the black cartridge then get a tissue paper try pressing the nozzle again the tissue paper but not so hard then release look for the straight line that appear on the tissue paper if it is not change it
Aug 07, 2011 | Canon Office Equipment & Supplies
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
When i print a document, ,txt or .doc doesn't matter, every other line of text is missing. Any ideas?
if you have the same problem printing a picture then the printhead is defective and should be replaced.
Oct 04, 2010 | HP Photosmart 8450 InkJet Printer
How do I fix canon mx310 which prints with lines
please check doc. page setup, may be outline or outside margin resulting not space.
Apr 15, 2010 | Canon PIXMA MX310 All-In-One Printer
User prints a Powerpoint 2007 doc and several of the slides have missing info. One has the upper left quadrant partially printing and two others have 3/4 of the slide partially printing. Fresh install of...
I would recommend you download the latest drivers for your printer, and also check to see if your powerpoint has updates as well.
also, its possible your printer does not have enough memory to print complex graphics, try reducing the quality or resolution of your file.
thanks adi
Dec 16, 2009 | Computers & Internet
Poor printing quality on text
so, what sort of text is it you are attempting to print? what program is in use?
Aug 15, 2008 | Dell A940 All-In-One InkJet Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Doc 12 Error Code
You Have to Clean a litle square reflexive patch that is located on the IBT Belt.
Just remove the waste developer botle, turn the orange handle CCW, remove the 2 external screws of the IBT Assy and pull out the Transport drawer and IBT drawer. clean the patch reinstall and thats it.
Feb 14, 2008 | Xerox DocuColor 12 Color Copier
Ms word 2007 docs print every other line
This seems like a print driver problem. You may have to get an updated driver for your printer for Msoffice 2007.
Sean
Nov 30, 2007 | Microsoft Office Professional 2007 Full...
Canon MP730 stops printing midstream
Is the issue the same with a anormal text document or just with heavily colored docs? If the text doc gets printed fine, then it is an issue with print spooler and we might need to work on that. revert & lemme know
Aug 05, 2007 | Canon SmartBase MP730 All-In-One InkJet...
Dell 924 All-in-One InkJet Printer Logo
145 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
