Question about Cobra Radio Communications
I have a 1990 cobra 148 GTL with 5 pin side-mounted mic. I recently bought a Barjan 5 pin noise canceling mic. Is the mic compatible with my cb, or do I need to change the wiring? Larry
    Genius:
  • 1,212 Answers
The wiring is not likely to be the same.
The information on the radio is here:
http://www.cbtricks.com/radios/cobra/148gtl/index.htm
You will likely need to open up the mic to identify what your wires connect to to determine the correct oreintation. it is possible too you may find one of the models listed was used by Barjan and is nothing more than a rebranded microphone.
Posted on Feb 19, 2012
5 Suggested Answers
SOURCE: I need to know if it's possible to convert the
5 pin to 4 pin as follows, from the Cobra website.
1.->2 Audio
2.->1 Shield and common
3.->4 RX
4.->also goes to pin 1
5.->3 TX
Posted on Apr 26, 2010
Testimonial: "This is exactly what I needed. Thank you very much."
audio20
  • 22 Answers
SOURCE: cobra 148 gtl dx manual
This is the Manual for the C148GTL
Posted on Apr 23, 2009
Ironfist109
  • 3018 Answers
SOURCE: schematic diagram of cobra 148 gtl cb radio china made
  • Locate the MB8719 chip that is right behind the channel selector. Wire a SPST switch from pin 10 to ground and another from pin 11 to pin 12.
  • Channel Chart
  • Position 1: sw1 down, sw2 down
  • NORMAL CHANNELS
  • Position 2: sw1 up, sw2 down
  • 15=26.815 20=26.885 25=26.925 30=26.985(ch3)
  • 16=26.835 21=26.895 26=26.945 31=26.995(ch3A)
  • 17=26.845 22=26.905 27=26.955 32=27.005(ch4)
  • 18=26.855 23=26.935 28=26.965(ch1)
  • 19=26.865 24=26.915 29=26.975(ch2)
  • Position 3: sw1 up, sw2 up
  • 1=27.605 6=27.505 10=27.555 14=27.605
  • 2=27.455 7=27.515 11=27.565 16=27.475
  • 3=27.465 8=27.535 12=27.585 20=27.525
  • 4=27.485 9=27.545 13=27.595 23=27.575
  • 5=27.495
  • Position 4: sw1 down, sw2 up
  • 1=27.605 11=27.725 21=27.855 31=27.955
  • 2=27.615 12=27.745 22=27.865 32=27.965
  • 3=27.625 13=27.755 23=27.895 33=27.975
  • 4=27.645 14=27.765 24=27.875 34=27.985
Posted on Nov 09, 2011
Ironfist109
  • 3018 Answers
SOURCE: cobra 148 gtlcobra 148 gtl DX
  • Hi, here is your users manual http://minus.com/m8geTULWN#1 just click "download" if you want a copy of it. I have a copy of the service manual as well. Let me know if you want a copy.
  • Hope this helps.
Posted on Nov 29, 2011
Galaxy echo 5 pin desk mike wiring to cobra 2000?
before you go thru all the trouble of wireing it ,what kind of radio did the desk mic come from.If it came from a galaxy then you shouldn't have to change a thing. 5 pin to 5 pin try it then if you have to wire it.
Apr 28, 2014 | Cobra 148 GTL 120-Channels Base CB Radio
148 mic wiring white d104
five pin /4 pin? (white D-104?)
five pin= 1-audio,2-shield,3-RX,4-comm,5-TX
4 pin=1-shield-comm,2-audio,3-TX,4-RX
Jan 03, 2014 | Cobra 148 GTL 120-Channels Base CB Radio
How to make a adapter for a 4 pin CB mic to a 5 pin CB Cobra 148 Gtl
they are factory made adapters on the market , look on www.copper.com or www.hyelectronics the should be listed on thier sites and the adapters are pretty cheap priced
Mar 30, 2013 | Cobra 148 GTL AM / Single Sideband CB...
Cobra 148 gtl-st wont transmit but receives great
Check first your microphone
• check if TX is engaging when PTT is pushed.
• check for continuity ( mic and cable )
If you have not done these steps,
try it first, or borrow other compatible mic for Cobra 148GTL
from your friends on air.
Jul 28, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
I need to know if it's possible to convert the cobra 148 gtl 5 pin mic jack to 4 pin mic jack.
1.->2 Audio
3.->4 RX
5.->3 TX
Apr 21, 2010 | Radio Communications
148 gtl 5pin
Looking from inside the radio at the mic jack, with the nub down. Starting from the left is pin 1, pin 2, pin 3, pin 4, and pin 5.
here is the colors that should be attached to each.
1 is white.
2 is sheild.
3 is black.
4 is red.
5 is blue.
Hope this helps. Take care in soldering. It is easier to reach the pins if you remove the 4 screws that hold the face plate on. Be careful not to pull another wire from somewhere.
Apr 20, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
5 pin mic
All "older", "real" or "desirable" Cobra 148 GTLs came with side-mounted 5 pin microphone sockets. For wiring information, see...
http://www.offroaders.com/info/tech-corner/reading/mic-wiring.htm
Feb 06, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra gtl 148 seems to have no power til i push on mic connecter.
cobra 148 shows no wattage output on external meter but does show good modulation.
Dec 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL steady tone though speaker
try rerouting your coax cable and make sure it's long enough
Jul 07, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
173 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
