Question about Sharp AR-M277 Black and White Copier
Copies too dark
Copies comes out too dark...page is black...changed exposure to lightest and they still come out black
4 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: My copied pages have a dark black line that runs
The blade that cleans the drum is worn out.
Posted on Feb 23, 2010
rezazadeh
  • 328 Answers
SOURCE: Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
Posted on May 25, 2010
  • 2072 Answers
SOURCE: My copies are not very dark
Is the problem only with copies? Does the machine also print light?
If is it copy only, remove the glass and clean the lamp and mirrors in the scanner.
If it is both copy and print, then you should clean the laser shield glass and replace the developer.
Posted on Jul 28, 2010
Every time i try to copy a letter but it comes out full black colour. what is the problem?
Does it do this both through the document feeder and off the glass?
Are you using a coloured original?
Try adjusting the exposure to the lightest setting.
Also try cleaning the main corona unit(instructions are in the box that the toner came in)
Aug 08, 2013 | Kyocera Mita KM-3035 All-In-One Laser...
Copies are too dark, even with the Automatic button turned off and the exposure set to lightest.
Hi which model are you talking about?
These is problem with analogue copiers like NP1550/6216/6030,...
Where these means that You need to clean optics, lenses because of dirt on them which is shown as dark copies.
Hope that helps!
Sep 09, 2010 | Canon Office Equipment & Supplies
May 25, 2010 | Sharp AR-5320 Black and White Copier
When trasmitting the receiver copy is totally dark
The exposure lamp is not coming on, try unplugging the machine for a few minutes. power it back up, Try making a copy, it uses the same parts as out going fax.
If that doesn't work, feed a page into the fax, press copy, if you look where the original comes out you should see a bright light, this illuminates the original so the scanner can see the page. If that lamp is not coming on the lamp or the control board for the lamp has likely failed.
Hope this is of some help.
Ed
Apr 26, 2009 | Office Equipment & Supplies
Black pages on every fax I send
Is sounds like your exposure lamp is not coming on, put an original in the machine and make a copy, if you look where the original is coming out, you should be able to see a light illuminatig the original so the scanner can read the image. If this lamp is not coming on you will get a very dark to black image.
If it is just locked up is may be as easy as this. Turn off and unplug the machine for a couple of minutes, reconnect and power up the machine, make a copy. as the machins uses the same parts to copy you should see the result of your efforts.
If the copy look good, try a test fax to someone, and call them for confirmation.
If this doesn't fix the problem, then I suspect the exposure lamp unit has failed.
Apr 17, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Cannon PC1061 making dark copies
OR you can do it yourself.
your problems seems to be Dirty Mirrors.
Your copiear has 6 mirrors that need to be clean up. 5 of them are kinda easy access. the other needs to be clean thru something thiner than your fingers. (you can see the mirror but no way you can reach it).
Now dont worry (not yet) about that 6th mirror since THEORICALLY it doesnt get dirty.
So try first to clean up the other mirrors. and see what happens.
They are located below the platen glass (remove it) and be careful with the lenses (do not touch them). clean everything that seems to reflect light Or images.
If nothing changes you may want to try out with a new cartdrige. Your drum may be done.
Oct 19, 2008 | Canon PC1061 Copier
Streaking
hi im jules_09.his there any error code?if no error code try to adjust the voltage on the exposure lamp,if that does not work can you send me a sample print at cmhal_09@yahoo.co so i can see the print .
Oct 14, 2007 | Toshiba 2060 Copier
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
Canon 6025
Your problem is most likely caused by dirty optics. Place a sheet of paper on the glass & make 1 copy with the lid up. Look under the glass at the mirrors on the scanner & see if there is any dust on them. If so,turn the copier off & unplug it from the wall, remove the glass & wipe off the mirrors with a DRY cotton rag. There are 3 mirrors on the scanner assy. There is also three mirrors under the lens cover that should also be cleaned. After cleaning the optics, make a test copy.If your copies are still to dark, press the additional functions key & select exposure adjustment. You can lighten/darken all copies by changing this setting. If you have any problems or questions my email is bspier@carlsonsupplies.com Good Luck!!
May 29, 2007 | Canon NP 6551 Black and White Copier
Sharp AR-M277 Black and White Copier Logo
54 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
