Question about Papermate Paper Mate Comfortmate Ultra Pencil Starter Set Ast Brl 070 mm Ref
How to refill eraser in comfortmate ultra - Papermate Paper Mate Comfortmate Ultra Pencil Starter Set Ast Brl 070 mm Ref
For 4 digit pass code on my leappad ultra
Resetting your leappad ultra isa breeze. First thing you need to do is to download and install Leapfrog connect. If it doesn`t download, there`s an offline download option available. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn`t maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased. Hope it helps
http://youtu.be/dnyle_-2aDYw
Dec 02, 2014 | LeapFrog LeapPad Ultra eBook: DisneyPixar...
Why is the cistern noisy when refilling
remove lid and look where refill hose is located should be attached and in fill tube [center tube ] if it is than your toilet s noise is normal --you can knock it down a little by turning down the water pressure[turn the external valve on the water line going into toilet ] turn it a little this will also slow refill time as well --and as to ultra quiet that s for the flush mode not the refill mode
May 09, 2014 | Caroma toilet - water saving Sydney Low...
How do you refill the Zebra M 301 mechanical pencil
pull the eraser out and put it in the end if that doesnt work pull the part holding the eraser and it should come out.
Jan 16, 2012 | Zebra M 301 Ultra Mechanical Pencil Black...
How do I replace my Helix eraser
With a small needle nose plier or tweezer pull the metal eraser holder out and put a new eraser in then stick it back into the body.
Thats it!
Nov 01, 2011 | Helix Auto Eraser, 1 Eraser (19060)
Please how do I refill my Bic Quantech #2 0.5 pencil? I have the correct size leads, but cannot figure out the mechanics. Thanking you, Margaret
Got it, thanks to the chap at OfficeWorks. Take the plastic cover off the eraser at the top of the pencil. Then wiggle the eraser out of its seat. Then you will find a hole going down the centre of the pencil, under where the eraser was. Drop a couple of leads into there, put the eraser back in, put the eraser cover on and Bob's your Uncle.
Cheers
Aug 29, 2011 | BIC Quantech Mechanical Pencil,...
How do you load a new lead?
To load more lead into the Zebra Z Grip mechanical pencil you must follow these steps:
1. Use the extra provided lead or purchase a refill package in 0.7mm size. 2. Remove the plastic cap that covers the eraser on the end of the pencil. 3. With the cap removed, gently tug the eraser out of the end. 4. When the eraser is removed, place a few pieces of lead into the open tube. 5. Insert the eraser. 6. Replace the cap on the end of the pencil. 7. Depress the end of the pencil a few times to feed the lead through the tip. 8. Write!
Mar 10, 2011 | Zebra Z Grip Mechanical Pencil, 0.7mm...
I defraged my card and now it does not work in my camera
An older mac could have rearrange the byte order and thus render the card unusable. Have you tried to format the card in the camera? If this doesn't work contact sandisk for a replacement.
May 26, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
I don't know how to erase a cd. i try deleting the folders, i am told its read only.
Hi, you can only Erase a CD that is RW. any other cd can't be erased. if its a R cd it can't be erased and those are one time cd's one time write and then it can't be erased and when its full you can't change it, you will need a new disc.
Mar 19, 2009 | Verbatim DataLifePlus Ultra Speed CD-RW...
Papermate Paper Mate Comfortmate Ultra Pencil Starter Set Ast Brl 070 mm Ref Logo
1,592 people viewed this question
Top Papermate Office Equipment & Supplies Experts
jhnolson
k24674
Are you a Papermate Office Equipment and Supply Expert? Answer questions, earn points and help others
