Question about Samsung Computers & Internet
I have a 320 gb hdd i don't know if it works properly or if it is fine but my laptop won't load up
  • Samsung Master
  • 27,725 Answers
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
hope this helps you
Posted on Feb 18, 2012
5 Suggested Answers
cinek79
  • 320 Answers
SOURCE: Seagate HDD 320 gb
you can try recover your data but it cost $$ or just buy new one
Posted on Aug 08, 2008
  • 146 Answers
SOURCE: HOW TO CHANGE 320GB SATA HDD TO 500GB SATA
Yes. The case doesn't care what size the drive is. The computer is just asking for the USB driver for the case. Check the WD site for the driver for the model of MyBook that you have. That should cover it.
Posted on Dec 27, 2008
SOURCE: MY WESTERN DIGITAL 320 GB HDD IS NOT DETECT
I have exactly the same problem with the same type of HDD. Did you find any solution?
Please let me know.
Posted on Oct 07, 2010
EMKartha
  • 163 Answers
SOURCE: 320 or 500 gb hdd
Install the drvier after downloading it from here... Good Luck.
Posted on Nov 09, 2010
Problem with not working right with dial up
Your dial-up relies on the internal modem to be working properly.
Check for your modem status using Device Manager.
If the listing for the modem has any yellow or red highlighting, then the modem software or hardware needs to be changed.
If you leave your PC plugged into a phone line, internal modems are easily destroyed by lightning storms or surges in the phone line.
If the Device Manager looks okay, then call your Internet Service Help Desk.
Feb 16, 2013 | Acer Aspire 5745P-373G32Mnks - Core i3...
Lenovo ThinkPad T520i Battery
Have you check your Charger for Proper Voltage? Is it Providing Proper Voltage to your Laptop? Check it First.
This Problem can Happen due to bad Charger or due to the Charging IC not Functional properly, which is located on the Board of the Laptop
Aug 11, 2012 | Lenovo 423947U - Thinkpad T520I 423947U...
Acer Aspire 5002WLMi Laptop won't recognize full 320 Gigabytes of new PATA hard drive. It's always been running a 80 Gigabyte 4200 RPM but that drive is old...a 2005 HD. New WD320 only reads 137...
The BIOS in the ACER determines the maximum size of the hard drive it can support.
Check the laptop's specification to see the max size you can install in this model laptop.
It appears that the max size your laptop can support is 140 Gb (unformatted). 137Gb formatted.
I suggest you install a hard drive up to 140 Gb capacity in your laptop and place the 320 Gb hard drive in an USB hard drive adapter case and when you attach this hard drive to the USB port in your ACER laptop then you will be able to get the full 320 Gb capacity after you delete the partition and create a 320 Gb partition and format the hard drive.
Nov 02, 2011 | Acer Aspire 5002WLMi Notebook
Hdd i/o firewire port won't work when connected with my hp probook laptop. do i have to install some drivers or firmware. when i use just hdd, things are just fine, evrything works fine. i need...
You cannot use the drive without external power, specially with the 4-pin firewire: there are some USB models that allow it (usually 2,5" drives), but you need 2 USB outlet oth the PC (one for the data and power, the second for power supply). About the compatibility you shouldn't have problems.
Aug 07, 2011 | Focus Enhancement FSHDD-1 (ASYF070701) 40...
My laptop turned off and now its asking for a primary user hdd password witch i dont have how do i unlock it?
You have to unlock the hard drive from within BIOS if you don't want to see that screen again. However, if you don't know that password then the laptop is not going to usable by you. Normally this prevents access to a computer in case someone steals it, since the thief won't know the hdd password and can't unlock it to access any data.
Jun 10, 2011 | Acer Aspire 3680 PC Notebook
Hello. My Lg Hxd5 500 GB external hdd is not being read. It was working properly but now the device manager is telling me that mass storage device is not installed. i tryed updating the driver but it...
Go back on Device Manager, right-click the HDD and choose 'Uninstall'. Go through this then unplug and plug back in the HDD. Hopefully if the drivers you downloaded are installed it will recognise it first time.
May 07, 2011 | Computers & Internet
I receive a no operation system message while booting
Buy a new hard disk drive! Use the 2 golden Gateway, Applications, Drivers, & Operating System disc, also known as Restoration DVD to reinstall your Gateway programs & operating system. After that, reinstall your backups.
How much disk space do you need? Why buy a 320 GB HDD if you only use 4 GB? So, keep the bytes down if you don't need them and that will keep the costs down, too!
The Gateway support discs can be had at: www.Gateway.com/Support .
~PC-Doctor
Nov 12, 2010 | Gateway (M520HD80G) Hard Drive
Can you let me know what is the maximum installable HDD capacity 0f Lenovo laptop 3000 C100.Can i upgrade present capcity of 40GB to 320GB ?
If you have windows xp with service pack 3, there is no limit. There is no limit if you run Vistaor Windows 7. If you don't have service pack 3, you are limited to 137 gb.
Dec 20, 2009 | Lenovo 3000 C100 Notebook
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
Computers & Internet Logo
73 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
