Question about Belling Kitchen Ranges
Belling range cooker db4900dft programmer broken and need to disconnect
The programmer has been getting more and more difficult to set as the with only intermittent response to buttons being pushed. Now after a power cut there is no response at all when I hold the plus and minus buttons in. I know how this is supposed to work, and it has worked in the past in a sporadic sort of way. The middle dot should start blinking and allow me to set the time and then use the oven.I don't need or want the timer anyway and am fed up with getting stranded with no oven. I just want to disconnect it and be able to use the oven manually. Belling say the timer can be disonnected, but charge an extortionate sum (£167) for a repair visit. How do I get access to the timer, and how do I disconnect it. (a family member is competent at this sort of thing, though not a qualified electrician.
  • artika Feb 17, 2012
    I am totally mystified at the "suggested solution" "translated" into gobbledygook, from the original gobbledygook dialect obviously, about a totally unrelated product (a door hinge maybe?) and posted a year ago. How does this answer a question posted today about a range cooker programmer???
  • 1462 Answers
SOURCE: belling db3 duel fuel cooker
they just pull out but need a fair bit of force
Posted on Apr 24, 2007
  • 13 Answers
SOURCE: User Manual for Belling Electric Cooker
The clock is flashing zeros because you need to set the clock timer.To do this you need to press and hold in both of the the cook period and end time buttons together, then with both buttons still held in , press either the "+" or "-" buttons to set the correct time of day
Posted on Apr 21, 2009
  • 2976 Answers
SOURCE: convert my belling DB90
You will have to change the orifice to accomodate lp gas.
Posted on May 08, 2009
  • 969 Answers
SOURCE: ineed a manual for a belling 913 natural gasrange
TRY http://www.applianceaid.com/fault_codes.html
Posted on Nov 12, 2009
  • 149 Answers
SOURCE: Tenho 1 fogão DCS-RG364GD à
i cant help but here it is translated to english.
I have 1 fogã£o DCS-RG364GD the 10 years and am needing 2 springs of the door of the Ref oven: 211344-30" Door Hinge Nuova Star and 2 lame person - Ref: 211346-Receptacle Nuova Star another one peã§a: 210828-Spark Module - amount 1 My son this ¡ in London, as faã§o to buy these peã§as wool ¡ I wait an Obliged return Isabel dabelgastronomia@ uol.com.br
Posted on Mar 27, 2010
I have a Belling 335 everything still works apart from the actual oven part? What could this be and is it fixable??
check your timer,if it has a programm set(by accident)the oven will not work until this has been cleared,if your not to sure then switch cooker off at the cookers main switch on the wall.leave for a few mins and switch back on this should clear any set programm,good luck.
Nov 13, 2012 | Belling 335 Electric Kitchen Range
Need to know if my cooker is a bayonet fitting
the bayonet fitting is on the end of the gas pipe that plugs into the gas main. look at the back of your cooker follow the black pipe you will see a brass end that fit to the solid gas pipe if you have a ring on the end of you flexible pipe that you can push in slightly and turn to disconnect you have a bayonet. its not the cooker that is a bayonet but the flexy pipe that is connected to your cooker. you can add one if one not fitted
Feb 02, 2010 | Belling Solitaire G755 Gas Kitchen Range
Aug 21, 2008 | Kitchen Ranges
Cooker keeps tripping the electricity supply.
If the main oven is electric, disconnect the heater element and try, if no trip operqates. then replace element.
Nov 22, 2007 | Belling CookCenter 151 Dual Fuel (Electric...
Belling DB3 Control Panel
Not easy. Briefly, in addition to the screws you mention, the cooker side panels need to be removed to give access to removal of the control panel side clamps. Then the indicator lamps have to be disconnected, and timer etc. buttons have to be pulled out to allow removal of the the control panel. Then the main control unit (timer etc.) needs to be unscrewed from behind the control panel.
Replacement is reversal of above.
Oct 27, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
63 people viewed this question
Top Belling Kitchen Ranges Experts
paulcarew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
