Sound no pictre
Briefly shows bush logo then goes no picture sound ok
  • 188 Answers
Check the inverter, probably one of the inverter transfo's is bad. Al must measure the same for example 800 ohms, if there is one with an higher value that is the one to be replaced. Measure at the lamp side, not the power side.
Posted on Feb 17, 2012
  • 362 Answers
SOURCE: we have sound but no picture on Phillips flatscreen television
Take a flashlight and shine it on the screen when you have sound, look very close, can you see a video image? If so the inverter is probably bad.
Let me know and I will assist further.
lone99star
Posted on Jan 08, 2009
  • 4 Answers
SOURCE: Westinghouse tv ltv46w1hd sound no picture
www.cfusion.com has the spare parts for that tv. it sounds like it is the mainboard. shouldn't be more than 150-200 to replace.
Posted on Apr 03, 2009
Bfsas1
  • 258 Answers
SOURCE: No picture sound only
your lcd tv is most likely not getting enough reception for the visual signal, try switching your tv back to analog signal (not digital) if you can by switching off av on remote, do you get your picture back, if yes thats your problem check your aerial, aerial leads and plugs, also do you have an aerial amplifier plugged into a power point, is it turned on to aplify signal.
Posted on Jun 22, 2009
budmrtn
  • 11361 Answers
SOURCE: the tv briefly powers up shows the memorex logo
The poroblem can either be the 12~18vdc power supply section is not supplying the power to the backlight inverter board or the inverter board went out, you need to check voltage on the power supply, also look to see if you see any caps with leaking/bulging top.
See example of failed TV and monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 13, 2010
Highdefjeff
  • 124 Answers
SOURCE: Tecknika lcd tv has sound but no picture, shows
Try unplugging and replugging the TV to cause reboot. After reboot do a scan for digital channels.
Posted on Jun 14, 2010
Need help troubleshooting no video on an LG 47LN5700 Television
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 07, 2016 | LG 47" 5700 Series LED HDTV - 47LN5700
In Samsung tv complaint<br/>in first time tv working in normal and after sometime picture is blinking and slowly no pictre. that time sound is also ok.<br/>after that am am change the capa
Check its solder terminal at the CRT board [Filament voltage]. It sounds like the filament do not glow after some time due to a loose contact at the CRT base connector sockets. Check it.
If this does not help, check the ABL circuit for any open resistor.
Oct 25, 2014 | Televison & Video
Screens shows but then gos black
Confirm that all the input cables at the back are securely plugged at the rear of the screen and PC/output source and that the image source is switched on and displaying an image. This can be done by switching your PC on and waiting five mins. Then check that the power for the screen is on. If this does not work, then let me know
Jan 31, 2014 | ASUS LCD Monitor
My Rival took a ride through the washing machine. After letting is sit for several months it will now turn on. However, it seems to be stuck in a continual reboot loop. It powers up showing the Verizon...
yes my friend open your phone clean all the parts by cleaning with thinner by using tooth brush .this because some water may have logged those parts.try your luck.if not get cleaned by your near by service centre.
Oct 06, 2010 | Motorola Mobility Rival A455 Cell Phone
The tv briefly powers up shows the memorex logo and then the screen goes black no picture, but stays powered up. And will not allow or show any functions please help
Jun 13, 2010 | Memorex MLT1921 19 in. LCD TV
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
We have sound but no picture on Phillips flatscreen television
lone99star
Jan 07, 2009 | Televison & Video
Lines in every pictre ,
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free (for the S1 IS), including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Feb 18, 2008 | Canon PowerShot S2 IS Digital Camera
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
