Question about Apple iPhone 4 Black Smartphone
My iphone 4 internet is not working with tplink wifi
I have WIFI issue with iPhone.
need more details to be able to help you. in the wifi section can your router be seen by the iPhone. Does the wifi on and off switch work in the preferences ?
Feb 10, 2015 | Apple iPhone4 4G iPhone 4
Tip
How to connect an iPhone to the Internet
Connecting your iPhone to the internet is an easy process. You just simply use any application on your iPhone which uses internet service.
Your iPhone can either use WiFi or Cellular for internet access.
- A WiFi network is simply a wireless network. You can find them at coffee shops, libraries or even at your house if you a router setup for wireless access.
- Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
When you use an application on your iPhone that requires internet service it will either connect to the last WiFi network used, or if that network is not available it will list all available networks in range. You can simply tap on the network you wish to join and it will connect. If the network requires a password it will show a lock icon. If no Wifi networks are available your iPhone will connect over the cellular data network and fees may apply.
To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
I hope this article was informative. You can check out more of my tech articles by clicking here then going to the Tips section.
Regards,
G33k
keywords
how to connect iPhone to the internet, connect to internet, iPhone internet, connect iPhone internet, how to use internet on iPhone, iPhone internet application, iPhone wifi, iPhone wireless internet connection, iPhone no internet, internet not working iPhone, iPhone 3g,
on Jul 09, 2011 | Apple iPhone Smartphone
Tether my iphone 4 for free
step 1 : From Home Screen select Settings
step 2 : Select General > then select Network
step 3 : Press Internet tethering to turn the function on
step 4 : Connect it to the PC using the USB cable or using Bluetooth
step 5 : Once handset is connected to PC , Select iPhone from the list of available connection using the Internet access icon in the system tray. Press connect and you'l be able to surf the internet using your device.
Apr 08, 2012 | Apple iPhone4 4G iPhone 4
My iphone is working to the internet
if your connecting to wifi just go to setings - general - network - choose wifi and find a open connection
Make sure wifi is on..
some connections require a wep password make sure you know it
if your connecting to 3g/4g switch off and switch on your cellular data in the network section of settings if your not getting a connection its the area your in is not a good connection..
Nov 03, 2011 | Apple iPhone 4 Black Smartphone
I have hiphone 4 wifi i can't setup internet setting claro pr: internet connection failed
The question is kind of vague but I would try one more time to make the iphone connect to the wifi. It that doesn't work, then try to reset your network setting. (Settings--General--Rest--Reset Network Settings) If that does not work you can try to reset the whole iphone or choose to do a restore, but you will lose all the preferences that you changed. Before doing either of those, I would make sure that the problem is not on the wifi side, try hooking up the wifi to a computer or another smart phone. Hope i helped.
May 04, 2011 | Cell Phones
Hello sir, i am using apple iphone 3g i am getting internet connection autometically so i am loosing money in the left corner of the phone letter E is always visible i wants to disconnect the internet pls...
1.Turn on your local Wifi either home or how so its temporaily disabled the 'E' Edge connection provided by your carrier provider
2.After the Wifi is connected
3.Open safari browser on your iphone
4.Type in the address bar www.iphonenodata.com
5.Scroll down to the end until you see a Disable EDGE/3G
6.Click on Disable EDGE/3G
7.You'll see a popup asking you to install a Profile
8.Install the profile and after the installation is done
9.Restart the iphone
10.Turn off the Wifi
11.Wait for 'E' to appear on the statusbar (Edge)
12.Try surfing the internet
13.If you get an error saying "Could not activate cellular data network"
14.You have successfully disabled the edge it will longer take your money if the phone is idle
Mar 27, 2011 | Apple iPhone 3G
Internet on iphone 3g??
Simply go to Settings > Wifi. If Wifi is off, turn it on. You'll see a list of available networks when you're in a hotspot. You can also have iphone tell you when you're near hotspots by turning on "Ask to Join Networks." You won't be able to use the internet when you're not in a wifi hotspot.
Oct 28, 2008 | Apple iPhone 3G
Apple iPhone 4 Black Smartphone Logo
55 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
