Question about Neff Ovens
Neff single oven B1476NIGB not heating
It has now stopped working - when turned on it makes clicking noises and the light flicks on and off - may be todo with the fact that i tried to open the door when the selfcleaning program hadn't finished.
  • 249 Answers
SOURCE: neff single oven
fan heating heating element gone replace it ;Ire close bye
Posted on Nov 28, 2007
SOURCE: GE OVEN SINGLE ELECTRIC JKS05BW
I have the same problem. Mine is a self-cleaning oven. But I'm just preheating it 450 and it did it. Then this AM it did it while broiling.
Posted on Aug 24, 2008
SOURCE: neff b1421 single oven
my oven is not reaching the required temprature what could the cause be please
Posted on Oct 15, 2008
apart4u
  • 213 Answers
SOURCE: replace fan motor in an electric fan oven
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 14, 2010
Testimonial: "thank you very much very helpful"
SOURCE: Have had 4 Neff oven elements in 2 years.
As barkencoa says, cheap elements from ebay etc don't last long. I proved this myself when my Neff B1320 fan element blew. I replaced it with one for about £10 from ebay. It lasted about 11 months. Last replacement I fitted was from Currys Partmaster. So far it's ok after 6 months.
Posted on May 08, 2010
Tip
Common heating faults with Neff B1644 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
on Jan 19, 2010 | Neff B1644 Electric Single Oven
Replace fan motor in an electric fan oven
Jan 13, 2010 | Neff B1421 Electric Single Oven
Oven not heating up
If the oven fan is working o/k, then all you need to do is replace the oven element, a straightforward repair, and cost effective, if no fan, then could be expensive.
Please rate my solution.
Thanks.
Sep 22, 2009 | Neff B1432 Single circotherm plus Electric...
Tip
Common heating faults with Neff B1476 single oven
on Jan 19, 2010 | Neff B1476 Pyrolytic Stainless Steel...
Tip
Common heating faults with Neff B1451 single oven
on Jan 19, 2010 | Neff B1451 Single circotherm plus Electric...
Neff single oven
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Tip
Common heating faults with Neff B1432 single oven
on Jan 19, 2010 | Neff B1432 Single circotherm plus Electric...
Tip
Common heating faults with Neff B1428 single oven
on Jan 19, 2010 | Neff B1428 Nostalgic Single circotherm...
Tip
Common heating faults with Neff B1641 Single electric oven
on Jan 19, 2010 | Neff B1641 Single circotherm super...
Tip
Common heating faults with Neff B1421 Electric Single Oven
on Jan 19, 2010 | Neff B1421 Electric Single Oven
Ovens Logo
24 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
