Question about Goodman GMS90703BXA Heater
Goodman capf1824a6ba fires up then cuts off
    New Friend:
Had the same problem; should be the flame sensor, sticks in the flame to monitor temp, take out and clean it or just replace, order on on ebay for ten bucks. Save yourself a 150 bucks to call someone.
Posted on Feb 20, 2013
  • spikhair
    spikhair Feb 20, 2013
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
I have a goodman furnace GMP075-3 rev B I heve the 4 flashes on the led but when I bypass all high limit sensors I still get 4 flashes and no fire. The unit also blows even when thermostat is at lowest...
One thing all of have to remember is that there is no one fix - for example went to one tonight that had this same problem - when I checked there was no power to the hi limit and if the rollouts trip ypu have to reset them (this tells you there is a problem and get if fixed, the problem here was a bad connection at the molex plug sso code flashes are idot lights to tell you THE AREA of the issue they are not the telltale problem if your hi limit trips it could be a clogged filer with no air flow cut the wire to the hi limit they will still be a 4 flash code and the problem is different
Feb 03, 2012 | Goodman GMS90703BXA Heater
I have a Goodman gas fired furnace. Serial number 0509077695 .How old is my unit?
6 years old.
For Goodman the 05 in the serial number is the year made.
Mar 08, 2011 | Goodman Heating & Cooling
I have a goodman GMPN1 gas furnace It goes through the cycle but doesnt fire. I replaced the ignighter it is working but still wont fire.
have you checked the pressure switch and also to assure that the flu is clear? can you light the burner with a match and when you do how long does it run for? have you checked the clearance to the burner have you also assured that where the ignitor is pluged into is cleaned ive also noticed on another site there is a board issue with this model have you checked the board ? also have a look at this site as well its where I usually talk with other techs about issues they have with the goodman as well as other units http://www.contractortalk.com/f6/goodman-80-furnace-brand-new-wont-start-7006/ please message me back with the answers to the questions that I have asked and I await your reply Thanks again Rick
Jan 31, 2011 | Goodman Heating & Cooling
Gas furnace model # gmb100-4 will not fire up ignitor working clicking sound afterwards but no firing up. Whats wrong
If induced draft motor comes on then ignitor tries to light but no flame I would change control board.I've had the same problem on several goodman heaters and all but one required new board. The other one was a bad gas valve but I would try board first. Hope this helps. Thanks
Nov 07, 2010 | Goodman GMS90703BXA Heater
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
Goodmans HDMI. After power cut (which it is used
I just left the TV off and it must have reset itself. It did it twice. First time it was OK after half an hour. Second time it was nearer an hour.
Thanks
Jan 08, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
I CAN CUT THE SYSTEM ON,IT RUNS A CYCLE ONE TIME BUT WHEN IT FINISH RUNNING STATUS LIGHT FLASHES 4 TIMES.BUT BLOWER CONTINUES RUNNING..... PLEASE HELP
follow the wiring diagram to find out where the safety switches are located. Usually one is found over the flame box. jump out the two wires to test the switch. If it is bad, the unit will fire up. If it still does not, check for more safety switches.
Mar 29, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
227 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
