Question about Siemens 24 in. SL84A305UC Built-in Dishwasher
Siemens Dishwasher SE23E231EU, Water starts then low flow indicator ( tap) comes on after about a minute. Have done all easy checks given in User instructions
Water left in bottom of machine which I can pump out using reset function. Machine fitted with Aqua Stop device.
4 Suggested Answers
  • 3 Answers
SOURCE: Dishwasher won't drain all the way
After cleaning the air gap thingy my machine works fine again. This thing sits on the left lower back side of the machine (left when you are standing in front of the machine). It is a transparent plastic box with 3 hoses attached (drain hose from pump, drain hose to the outside and water). Inside the box is a black plastic float. If debris gets caught in there the float gets stuck.
Solution is to remove the part by pulling the 2 drain hoses out (there is a small black clip holding them in) and unclamp and remove the water hose. Rinse and shake the housing until the float moves freely again and reassemble.
Posted on Dec 28, 2008
BElectric
  • 1140 Answers
SOURCE: Hello, i have a Siemens
It's possible that the Aqua-Stop flood protection system has been activated. I can probably help you, but I really need more information.
1. When you start a wash program, can you hear the pump running? - This will be a low pitch humming sound.
2. There is a dome/mushroom shaped plastic protrusion in the bottom of the washing compartment, located behind and between the salt compartment cap and the drain. Can you lift this up (be gentle) or is it already up and can only be pushed down?
Please post this information and I will try to assist you further.
Posted on Oct 27, 2010
Macmarkus
  • 2605 Answers
SOURCE: My dishwasher won't switch off
Welcome to FixYa.
Based on your description
I'd say the issue actually is with the control...unfortunately. This is commonly associated with a heating fault on Bosch built dishwashers ( various models including Bosch, Thermador, Siemens, Gaggenau, and Neff ).
Since the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
These are the steps you'll need to follow to resolve it or at least investigate.
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...this can also manifest as a long cycle time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning, no heating ( don't be fooled by the homes inlet hot water temperature ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e. ( this may differ from your specific model, but the same rules apply )
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last.
Bosch recommend`s replacing the control and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Feb 26, 2011
We have a Siemens dishwasherSN66T091GB. The unit is not showing a fault code but the 'tap' light and 'rinse aid' lights are flashing continuously.
Tap symbol indicates a water problem.
Check that the water supply to the dishwasher has been turned on.
Check that the water supply hose hasn't bent or kinked.
Check the water supply first, see what you find.
Rinse Aid symbol light indicates low on rinse additive.
Hope this helps?
Oct 16, 2016 | Siemens Dishwashers
E5 smeg dishwasher
Water inlet solenoid valve faulty. Check this is voltage to valve when water should be flowing. Replace valve if there is voltage present.
Jun 04, 2014 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Error code E:14 Siemens Dishwasher - stops after 1 min of cycle
It might be helpful if you provide the full model number of the Siemens dishwasher. Most likely E14 error has something to do with water flow sensing. Check if your mains water pressure is ok (tap under sink is fully open). But can provide more details only if you can tell me the model number.
Apr 03, 2014 | Siemens Dishwashers
What does F6 mean?
The dishwasher can't take on water. Check that the water inlet is properly connected, the stop tap valve is open and that water supply is otherwise available to the dishwasher. Also check for kinks or blockages on the water hose.
F6. means "Water valve (WV1) is switched on but flow meter (FM) senses no impulses" (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
Jul 25, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
Bosch dishwasher working for 2 minutes and saying check water and coming up e14
Possible that the inlet flow of water is low and so there is time taken to fill up . So check the pressure at the inlet. Also if the water level pressure sensor is faulty then the program will be halted as the water level is not indicated.
Please check the sensor.
Mar 30, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Start light flashes 6 times
6 'start' led blinks indicates
WATER TAP CLOSED
Water walve is switched on but flow meter sends no impulses or sends less tan 10
impulses in 10 seconds and the water indicator is off (empty)
posible reasons:
water tap closed
water inlet hose closed
water inlet valve defective
flow meter defective
remember to unplug it from power if any repair is done
Best regards and good luck
Oct 04, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Siemens dishwasher
My siemense dishwasher (2 month old) stopped working
No matter which program I choose, after 1 min the program stops and I get "tap" symbol on the led display.
Instructions says it might be a problem with the water source but i checked and it is fine.
ideas?
Aug 17, 2008 | Siemens 24 in. SE25T250 Free-Standing...
SIEMENS SE64630GB NOT TAKING IN WATER
  • hot water valve selinoid and cold water selinoid valve are magnetily operated valves located in the lower part of the dishwasher that need electricity-----
  • wire loose?
  • kinked supply hoses and
  • my favorite is the valve at the kitchen sink angle stop is lying to you, indicates open but is really still shut (broken valve stem) or it has corroded shut .
Aug 14, 2008 | Siemens 24 in. SE64A630GB Built-In...
Another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Nov 02, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Siemens 24 in. SL84A305UC Built-in Dishwasher Logo
115 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
