Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Kenmore side by side
Freezer is frosting over and seems tooo cold and the refrigerator side is too warm. Seals are good and I vacuumed underneath. We have it emptied out and unplugged! ahh any help?? Thanks
  • flanders32 Feb 25, 2009
    how do you know if the refrig is in def mode?
  • Anonymous Mar 02, 2009
    I have frost buildup as well, and the drain at the bottom keeps freezing over, and today I noticed the Ice make and the lights in the freezer side stopped working, I've already called the repairman, but I'm still curious as to the possible causes. I replaced the ice maker about six months ago, everything was working fine until about two weeks ago....
    Problem Solver:
  • 5 Answers
Sounds like the evap is frost up ,ice buildup.Make sure the ref. falls in defrost.If it does the problem could be faulty thermal disc or defrost heater.When the ice build up you will have no air flow and the ref side will be warm.
Posted on Feb 14, 2009
Why does my refrigerator keep acting up the freezer gets frosted up then the frig gets warm I have cleaned it underneath unplugged it for 24 hours then plugged it back in it works great for about a w
This problem can have many causes, but generally it is a defrost issue. If the freezer coils are frozen over, they block cold air flow to the refrigerator; and can be caused by different part failures. See the link below for a good explanation of possible failures and for parts. Also, if you turn the refrigerator temp to 0ff and unplug the refrigerator then plug it back in, it should go into defrost mode. Leave it that way for 15 or 20 minutes, then unplug and plug it back in. It may resolve the defrost mode problem. If not you'll need a part, or repair man. Kenmore Refrigerator Freezer is Cold But Refrigerator is Warm
Oct 18, 2014 | Kenmore Refrigerators
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
Nov 27, 2013 | Kenmore 53542 / 53544 Side by Side...
I have a Frigidaire side-by-side refrigerator model FRS26ZNHB1. The blower is running continuously and the temperature in the freezer is not as cold as it should be. (Ice cream is soft - things are...
bad door seals, frosted up coils, low refrigerant, dirty/clogged condenser coils (under fridge), bad condenser fan. check the fan in the back. clean out the coils with a vacuum under the fridge. see if there is frost on the back wall of the freezer. if there is, you'll have to remove the back wall and defrost the coils with a hair dryer. check the door seals for leaks. replace if necessary. if all is well and still warm, you have a freon leak. call in the pros.
Nov 13, 2009 | Refrigerators
Frig too warm, freezer works great, but frost on back wall
It sounds like the fridge is not going through the defrost cylce due to a faulty defrost thermostat.
Aug 29, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 5458 refrigerator too warm. Freezer
It is probely freezing up. The cool comes from the freezer to the ref. side and when it does not defrost it builds up frost or ice and then the air can not get through. Could be a timer or a defrost heater.
Aug 04, 2009 | Kenmore Refrigerators
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Whirlpool ED5PHAXSB side by side refrigerator not cooling...
There are a lot of possibilitys. You'll have to use the process of elimination.
But it could be the thermostat (make sure your setting is midway) The milk spoiling indicates it is too warm so bacteria is breeding
Get a refrigerator / freezer stand alone thermostat (about $5) That will give you accurate readings. The fridge shoud be between 35 and 40 F and the freezer 0 plus or minus 3 when set correctly
It could be your condensor fan is clogged or just that your coils need cleaning (underneath or behind) Use a vacuum with the brush end or chisel point. Dust can cut you efficiency by 20 or 30% by itself.
Assuming this is frost free model the defrost timer may be acting up in the freezer.
Forgive me for not knowing where the coils are and if it is frost free but I can't find a manual for this particular model. However the principles apply in any case.
May 09, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Kenmore coldspot model:10653502330 does not stay cold
hi thanks for the question i would check the back by the compressor make sure its clean . then check the fan in freezer to see if it works then see if the frost built up in freezer you could have just a dirty condenser thanks the appliance doc
Sep 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
104 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
