My furnace makes a banging noise all the time installed new pump, regulator expansion tankand
  • 366 Answers
SOURCE: new starter loud banging noise when u start it
could be! can be cracked,could have damaged drive gear tooth on it! could be starter that became loose also! inspect it asap before damaging new starter or fly wheel!
Posted on Apr 18, 2009
  • 13 Answers
SOURCE: washer frigidaire GLTF1670A
you need a new drum, wich is pretty much like buying a new machine
Posted on Jun 18, 2009
  • 28 Answers
SOURCE: New Kitchenaid refrigerator often makes sharp bang noise.
I have an old Amana bottom freezer that does that. It's because the defrost heaters are doing their job and the area around them as well as the coil is expanding rapidly. Try making certain that the cabinet is level and not on an unsteady footing. You might want to try turning the T stat in the freezer to a lower setting. Usually between 2 1/2 and 3 1/2 works best in all freezers. If none of this helps and the banging continues, get used to it or get another fridge. It seems to be a failing in bottom freezer models for some reason. It's harmless but annoying. I actually know someone who says she has the ghost of a frozen turkey stuck in her freezer that's trying to get out! LOL!
Posted on Jul 09, 2009
  • 3519 Answers
SOURCE: I just had a new COZY L.P. GAS CDV336C installed... Every few minutes it makes a loud bang noise...It then makes pinging noises that gradually fade out...This happens 2-4 times every hour. The bang is
Hi Loretta:
I'd contact the installer. This sounds as if there may be a slow leak. When the gas concentration is high enough it will ignite which would be the bang that you hear. The popping sound could be the flame at the leak source point re-igniting for a few times.
DEFINITELY CONTACT YOUR INSTALLER OR GAS INSPECTOR. THIS IS A SAFETY HAZARD.
Posted on Mar 11, 2015
AndrexT
  • 19606 Answers
SOURCE: My furnace is really hot you hardly can touch it and makes a banging noise when it turns on and off
Get it serviced. The banging might be water boiling, and that can explode with over pressure. There is a relief valve, but they stick. Or it could be a build up of gas and what you are hearing is a mini gas explosion. The overheating might be a flue obstruction. Too much going on, sounds dangerous, get it fixed professionally. You can't muck around with gas appliances.
Posted on Feb 28, 2016
I just had a new COZY L.P. GAS CDV336C installed... Every few minutes it makes a loud bang noise...It then makes pinging noises that gradually fade out...This happens 2-4 times every hour. The bang is loud...
Hi Loretta:
Mar 11, 2015 | Dryers
Drain and refill of New Yorker forced hot water furnace
Draining is the easy part. Isolate the water feeder (shut off). Open hose bib @ boiler, & open the expansion tank valve to pull air in to allow more water out.
Refilling- let the water feeder fill -should be around 12 Psi, then go around the building to all the baseboards or radiators & open the bleeder key valves to let the air out until you get a steady stream of water. Most of the air should work its way to the expansion tank. Turn the boiler on & test your new pump.
Nov 12, 2013 | Heating & Cooling
Rattling expansion and contraction noise, seems to come from header area toward top of heater
I would suggest an insulation foam. Should help to reduce the rattling and some of the expansion pops. Or you could brace the ducting, ducting is very thin metal and moves fairly easily if built real loose.
Mar 04, 2013 | Williams Furnace. 35,000 Btu/hr Monterey...
MY GOODMAN HI EFFICIENT GAS FURNACE GMH950703BXA ,MAKE A CRAKING NOISE WHEN THE BURNER LIGHT UP AND IT GET LOUDER
Is it a cracking noise or does it sound more like metal stress (expansion & contraction)? If it's metal expansion, there may be a loose duct connection or strapping. If it's not metal expansion and contraction, check the burners for cracks, due to humidity dripping on them. If that's the case, obviously, they will need to be replaced. But, the question then is, where is the over production of humidity coming from. Is the Condensator pump not working properly or is the drain clogged up?
These are the thinkgs you need to check first.
Hope this helped you troubleshoot the problem.
Apr 07, 2011 | Heating & Cooling
My cozy furnace makes a loud clicking noise every time it is running. What can I do to fix this problem?
Wall furnaces sometimes do that it is just expansion and conttraction of furnace. rus
Mar 17, 2010 | Heating & Cooling
We just bought a brand new Luxaire 95.5% efficiency gas furnace. The ductwork, electric, and everything you could possibly need for a furnace is new. The blower door is sealed and there are no vents and I...
gas build up and delayed ignitionYou may need a fan in your exhaust vent/stack. They are called power vents .The com in a tube the same size as your exhaust and need to be wirred for turn on whenthe heater is turned on. It is dangeroous in this state/setup. Consult with your installer. Good Luck and be safe._Ned_
Oct 06, 2009 | Heating & Cooling
Furnace clicks multipal times while running.Is this normal?
As it starts and stops several switches will open and/or close, sometimes you can hear them. When it's just running then it may make a few noises from expansion and/or contraction.
Mar 30, 2009 | Coleman Heating & Cooling
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
