Question about GE VG2042 VHS VCR
Timer What combination of keys do you use to deactivate the timer?
  • 3 Answers
You first must have the original remote, go into the menu, and go to timer settings. You cannot use most universal remotes to go into menu funtions. You can get an original replacement at http://remotes.com Good Luck
Posted on Aug 19, 2006
How to set legrand timer switch 12 hours model # 037-55 microrex qw31
QW31 is 7-day analog timer, 230 Volt
http://waterheatertimer.org/How-to-set-timers.html
If there is a photocell override, then it will be wired into terminals U1 and 4, and will not be part of the timer setting
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 15, 2014 | Legrand Ivory Universal Timer Controlled...
Timer wiring
there should be some schematic on the new timer , if you can send it can help to understand how to configure/ or at least the brand and model for the timer can help.
Sep 30, 2017 | Hardware & Accessories
Are there instructions on line on how to set the ACE 265 timer? If there are, please give me a link. Thank you.
Copy following link for instructions how to set analog timer:
Also decide if you want to use timer or use built-in thermostat operation:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Add a comment and describe timer in detail so correct identification can be made
Jul 13, 2013 | Taco 265-1 / 563-2 Combination Analog 24...
Frigidaire gas range model ES330 error code SAb
This is SB mode, show room mode. To deactivate showroom mode, remove power and reapply. Press Cancel to bypass programming clock. Within 60 seconds of reapplying power, press Oven Light key and top oven Timer key simultaneously.
Aug 05, 2012 | Kitchen Ranges
Need to turn timer off on sharp aquos lcd tv
Using your Sharp Remote go to Menu,Find Sleep or Timer Function Disable
Dec 29, 2011 | Televison & Video
Clock does not rotate
If clock does not rotate, then check if outlet has power. Check for loose wires.
If clock rotated before and stopped working, then clock motor might have gone bad.
Replacement clock: Taco timer uses the FM1 timer module.
Voltage and timer information appear on back of timer.
Open following links to identify timer and model number:
http://waterheatertimer.org/images/FM1-5-image.gif
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/modular%20din%20rail%20timers/fm1%20series%20-%2024%20hour%20and%207%20day.aspx
For example Taco timer module is 24 hour, and 120Volts, and doesn't have battery back-up.
-If timer has on-off-timer switch, then model number is FM1STUZH-120U
-If timer does not have on-off-timer switch, then model number is FM1STUZ-120U
More resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM1
Sep 17, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
I have a timer TX12674T im trying to reset the time by holding time and hour the screen resets itself to 12:00 any combination will rest the screen. what to do?
Timer is not identified.
My files, and web search do not show TX12674T timer, Aug 2011.
1) Add a comment with in-focus photo of your timer posted on flickr for possible identification.
2) I don't have repair for defective timer: What does your instruction manual say? Did timer work before and stop working? Are you using timer for correct Load? Try timer on different outlet and with different Load. Test outlet with circuit analyzer. Timers usually come with 1 year limited warranty.
3) Maybe you have TX12874X. This timer is reset by holding down Hour and Minute button.
4) Open following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Aug 13, 2011 | Timex EASY TO SET TIMER BY TIMEX
In the Intermatic ST01C, what is the function of the red wire in a two-switch set-up, which [after the second switch] goes to the same place as the [timer-switched] blue wire?
ST01C is battery operated timer with red, blue, black & green wire.
Red wire is used when replacing 3-way switch (for ex: light switch at each end of hall)
Red wire is capped off when replacing single-pole switch.
If red and black wires are combined, lights will blink.
If red and blue wires are combined, timer reverses ON-OFF function (just like a 3-way switch reverses).
See wiring diagrams for ST01C
http://waterheatertimer.org/ST01C-program.html#ST01C
Nov 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I bought a new house and the water heater has a circulating pump with a Taco 265 timer. No instruction manual so I can't figure out how to set the timer. You wouldn't happen to have a little instruction...
Maim website:
http://www.taco-hvac.com
Main website Search for Taco 265-1 gives link to manuals:
http://www.taco-hvac.com/search.html?gsearch=Taco-265-1&action=results&cb_products=YES&cb_filelibrary=YES&cb_news=YES&search_type=all_terms
Direct link to pdf manual:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.taco-hvac.com/uploads/FileLibrary/102-067.pdf
Instructions show series of actions to set digital program
Press h key ...
Press m key...
Press Day key...
Press Prog. key to enter...
Sep 10, 2010 | Taco 265-1 / 563-2 Combination Analog 24...
Gate stays open and does not close unless timer switch is turned off
I have a brand new Ramset 300 electric gate opener. My problem is in the early morning when the loop opens the gate it will not close unless deactivated manually. It does not happen later in the day with my GMC truck but happens early in the am with my husbands Toyota Prius. Please help. What can be the problem?
Jun 19, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Televison & Video Logo
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
