Question about Zyxel PLA401 bridge (S6698772)
How to Reset PLA-401 Series - Zyxel PLA401 bridge (S6698772)
401 startup freezes
Maybe try to reset the whole device (or is this not an option because there are files on there that you need?) I found a link to garmins official help page: How do master reset my Forerunner 410 405CX or 405 I hope that after resetting the device, it will work again.
Feb 01, 2014 | Garmin Foretrex 401 Handheld GPS Receiver
Is a house plug with a cfic braker light suppose to be red or green
Most are green when functioning properly. Many have no lights at all. Try depressing the reset and see if the outlet works again. If not there are other things to look for. Often times one GFI outlet feeds multiple more outlets from the "load" connection on the back side of the GFI. If there is something wet, overloading the rating, or something with a fault in any of the outlets multipled off the single GFI it will trip. Disconnect all devices then attempt to reset. If that doesn't work and you possess some electrical skills pull the GFI outlet and disconnect the wires going to the "load" connection (While power is off) Re-energize and attempt to reset the GFI Outlet. If it resets your problem is beyond that outlet in the circuit of what you disconnect. You may not have found all the affected outlets. FYI if you have a 15amp GFI the rule of thumb is you can put more devices on outlets working off or through the GFI that add up to more than 1500 watts. If it is a 20amp GFI a quick rule of thumb is no load over 2000 watts. Space heaters, blow dryers, and hair curlers are often 1800 watts each. One alone and can trip a 15 amp GFI.
Dec 28, 2012 | Zyxel PLA-401 v3 - Bridge - Ethernet, Fast...
What does a red light for powerline activity mean?
It indicates your line quality for the Homeplug - Green: Best, Amber: Better, Red: Good
Details here http://www.zyxel.com/uk/en/products_services/pla_401_series.shtml
Jul 16, 2012 | Zyxel PLA-401 v3 - Bridge - Ethernet, Fast...
" 401 unauthorised " is the error message i
No, but you can just reset the whole router and start from scratch. Hold the reset button on the rear of the router for 60 seconds and your will restore the unit to defaults, at which point you just need to reconfigure all of your configuration settings and password, as well as your wireless access code. Let me know if you require any additional assistance.
Jul 30, 2011 | Linksys Wireless-G WRT54G Router
Plantronics voyager 500a ~ Trying to sync the headset with the base How do I do it? Do you have a link?
http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8165&p_created=1128461658
Jan 05, 2011 | Plantronics Voyager 500A Deskphone Adapter...
500a will not pair with cell phone. my phone will pair with another bluetooth device so my phone is not the problem. I just got this 500a --- is there any special thing I need to do to pair it with my...
The Voyager 510 headset that's used with the 500a is compatible with most mobile phones. The link below has information that can be of benefit to you, especially page 5 (powering the headset on / off to reset) and page 6 (pairing).
Plantronics Voyager 510S User's Guide
Good luck from Headsets Direct!
Dec 23, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Zyxel PLA401  bridge (S6698772) Logo
144 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
