Question about Ricoh SP C320DN AllInOne Laser Printer
Error sc543 sp c320dn
Can anyone help me finding service mode for this printer so as to fix this error code ?
  • Anonymous Mar 18, 2014
    sp c320dn cs543
    Problem Solver:
  • 17 Answers
SC542, SC543, SC544, SC546,
These codes are related to fuser temperature. Make sure that power source voltage are not low. check thermisters, fusing lamps etc. To reset this code press "All clear" yellow key, enter 107 and press the red key for some seconds. Sevice mode will be displayed, enter SP 5-810 (SC code reset) and select "1". Then hold down the Photo mode key and the # key at the same time for at least 3 seconds
Posted on Feb 17, 2012
  • pankaj singh
    pankaj singh Mar 23, 2017
    sir sp310dn only tiw key but i no key reset
  • 9 Answers
ODCaloney has some helpful information, but none of the other answers are correct for this model.
C320DN - Error code: SC543
The fix below is for INFORMATIONAL PURPOSES ONLY. The best path forward when trying to fix your printer is to CALL RICOH support at 800-742-6438 and use Option 1.
You took the time to google/bing/yahoo this answer, take the additional time to call RICOH as they are the definitive experts on their products.
Error / Model specific instructions.
Error: SC543
Model: Ricoh Aficio SP C320DN
First, enter service mode:
Press and hold the UP & DOWN arrows for 10 seconds
(The screen will NOT indicate any change upon release, this is expected)
Press Ok.
Use the down arrow to select "Engine"
Press Ok
Use the Right Arrow to select "5. Mode"
Press Ok
Use the Left Arrow to select "5.810 SC Reset"
*CAUTION* If it says ANYTHING OTHER THAN "5.810 SC Reset" then do NOT continue. - Call Ricoh...
Press Ok
Press the "Up Arrow" key that is beneath the "Execute" option on the screen.
Again, Press the "Up Arrow" key that is beneath the "Execute" option on the screen.
Power Off/On as told to do so by on-screen instruction.
I hope that you called Ricoh and that they confirmed these instructions for you.
Best of luck,
Chris
PS: Call Ricoh (800) 742-6438 Option 1
PSS: They will ask you for your serial number, on this model it's on the back, lower-right corner.
PSSS: Call Ricoh
Posted on Mar 11, 2015
5 Suggested Answers
ODCaloney
  • 260 Answers
SOURCE: the wrench icon is on and code SC543-00 show up in the screen
That code indicates a fuser overheat error or hot roller fusing lamp overheat. Refer to your manual if you have it. Good luck.
Posted on Mar 16, 2009
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
EmmettPinger
  • 63 Answers
SOURCE: Error code SC543
press .....clear modes 1-0-7 and hold clear/stop until the screen changes to service mode then unplug the machine and plug it back in and turn it back on Good luck
Posted on May 04, 2009
drichards
  • 87 Answers
SOURCE: Ricoh SP C410DN error code SC306
Reaseat the cyan photo conductor
Posted on Feb 23, 2008
Iam getting sc543 for ricoh aficio printer SP C220N,Kinly help
Its a fuser error code Must be reset sp 5-810 in service mode.-Carl
Sep 18, 2017 | Ricoh Office Equipment & Supplies
Ricoh printer aficio SP C320dn has an error code SP 397? any help?
542 an error in temprator .may be termistor dirty or defective.termostat or lamp check all.then reset by :c(yellow)-107-c(red.press 3 second)-then turn off and on
Jun 03, 2016 | Ricoh Aficio Office Equipment & Supplies
What to do with error sc543?
fuser error will need to fix fuser first then reset code
Oct 08, 2014 | Ricoh Aficio SP C231SF SPC231SF SP C232SF...
Error sc542
SC542 is a fuser related error code, this will need to be reset.
Probable causes are:
• Defective thermistor
• Incorrect power supply input at the main power socket
• Defective fusing lamp
Corrective actions :
1. Check the voltage of the wall outlet.
2. Replace the fusing unit
3. Replace the fusing lamp.
Resetting the code:
Execute "Fuser SC Reset" with Some (printer models) or "Engine Maintenance Menu" (MF model) to recover the machine after completing the recovery procedure. Otherwise, the machine continues to issue this SC code and cannot be operated.
Sep 02, 2014 | Ricoh Aficio Sp C320dn Laser Printer -...
Ricoh Aficio SPC320 SP mode
hold down up and down for 5 seconds and then hit # -Carl
Jan 31, 2014 | Ricoh SP C320DN AllInOne Laser Printer
SC543 ricoh Aficio 1027
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermostat open
• Poor connection of the fusing unit
Inspect all the elements before mentioned, soon presses total clear (Yellow Key) 1 0 7 and Maintain pressed clear stop key (orange key) more tan 3 sec. Enter SP 5-810 (SC code reset),
select execute, select close. Exit SP mode, turn the main power
switch off then on.
If the problem continuous the problem can be in the Power supply board, can be defective.
Aug 10, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
RICOH AFICIO 650 WHAT DOES THIS ERROR CODE MEANS SC543-00
Try changing the termistor, must be damaged. and reset by total clear, 107 and press and hold the clear stop key more of 3 seconds.
Dec 03, 2008 | Ricoh Aficio SP C811DN-DL Printer
Error code SC543
Aug 15, 2008 | Ricoh CL4000DN Laser Printer
Ricoh SP C320DN AllInOne Laser Printer Logo
5,674 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
