Question about Vacuums
Wet and dry pullman janitor manual for A-031B
Manual for wet and dry use
Pullman vacuum model AS5 user manual
Hi There, The Pullman AS5 is exactly the same machine as a Cleanstar Hypervac AS5. If you email us on the VacuumSpot contact us page I can forward it to you.
May 25, 2013 | Vacuums
Manual for vax 121 wet & dry hoover
I need a VAX wet/dry vacuum model 221-07 manual.
Apr 28, 2011 | VAX Appliances V037 Stick Wet/Dry Vacuum
How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Nov 04, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Dry/Wet vac is blowing instead of vaccuum
Check to see if the plastic ball is stuck . There should be a ball under the motor , make sure it moves freely. Make sure your vacum lines are not plugged . Best of luck Ed.
Jun 18, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Manual for Bissell 1672 BIGgreen Wet/Dry Vacuum
You can download the Manual at http://www.bissell.com/images/UserGuides/1672.pdf, I hope this helps.
Aug 06, 2008 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Cleaner won't dispence cleaning solution
I have the same problem and each time I have to get the thing sent to Sydney to get the hose cleared out. Costing me $60 to $80 a pop.
Mar 10, 2008 | Pullman Holt Vacuums
Need replacement manual
Go to Sears.com, click on the parts link, put in your model number, a parts list will come up, if you manual is available, you can click on it to buy it.
Jan 01, 2008 | Craftsman 17740 Wet/Dry Vacuum
Wet vac has no suction
check for clogs in hose. maybee clogged filter, clean or replace.
Nov 09, 2007 | Pullman Holt EVAC II 15 Gallon Wet/Dry...
Vacuums Logo
452 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
