Question about Minolta DiALTA Di181 Printer
Dialta di181 clear M4 error code - Minolta DiALTA Di181 Printer
  • Minolta Master
  • 6,161 Answers
M-4 replace the drum it has reach the max of 80,000 copies. replace the drum then clear the counter. just clearing the counter will not be good the machine knows when the counter is clear it has a new drum and will adjust High voltages accordingly if the old drum is in there then you get code and image problems
try web site below for part start with drum being replace recommend the cleaning blade also be replaced. Don't for get to clear the counters first install the drum and run F5
Posted on Feb 19, 2015
2 Suggested Answers
jqsababa967
  • 145 Answers
SOURCE: minolta dialta di181 c1300 error
C1301 errors after setting up the Di181.
Solution:
Replace PWB-A, part number 1177-0106-03 for C1301.
Posted on Oct 21, 2008
Code M4 erro
Service mode, first
1.Press the Utility key.
2. Press the Meter Count key.
3. Press the following keys in this order:
Stop  0  0  Stop  0  1
for security "Stop 9"
In Security, Select Copy Kit
1. Touch "Set."
2. Press the Clear key to clear the current setting.
If the setting is accidentally cleared, press the Interrupt key to
undo the clearing operation.
3. Enter the desired value from the 10-Key Pad.
4. Touch "Current."
5. Press the Clear key to clear the current value.
If the current value is accidentally cleared, press the Interrupt key
to undo the clearing operation.
Jan 15, 2014 | Konica Minolta DiALTA Di200 Copier
Code m4
a maintenance counter has to be cleared. this can only be done by a technician
May 26, 2013 | Minolta DiALTA Di181 Printer
How can I find the driver of my Minolta DiALTA Di181 Printer compatible with Windows 7 ?
SORRY NOT GOING TO HAPPEN Di181 is a legacy first generation digital copier at best try windows95? Try this if you do not believe
Self Help Product Support Konica Minolta Business Solutions Inc
Oct 26, 2010 | Minolta DiALTA Di181 Printer
MY MACHINE DI 181 SHOWS SERVICE CALL M4 AND DOES NOT COPY
This M4 code means that your drum life is over. You have run 80,000 copies or more on the drum. If you have a local service company available then I would just have them come out and clean the machine and reset the counter. This is especially true if your copies were still fine prior to the machine shutting down. Service mode entry and navigation is rather complicated on this machine so I do not feel comfortable trying to walk you thru the reset process.
Good Luck and Thank You for using Fixya.
Jun 10, 2010 | Minolta DiALTA Di181 Printer
Minolta di 181 error M4
This means that the drum has reached it life count of 80,000 copies. If your copies are good and the machine is still making copies the you can just ignore the M4 as if you are in the USA then the factory settting allows you to continue making copies. If the M4 appeared and you can NOT make copies then you will need to get into the service mode to turn the disable copy feature off or reset the count for the drum unit. Just let me know what your situation is and if need be we can walk you thru the reset. I just don't recommend this action unless it is absolutely necessary.
Apr 14, 2010 | Minolta DiALTA Di181 Printer
Minolta di 181 error code M4
QUEL EST LA SOLUTION POUR DESACTIVER L'ERREUR CODE M4 ?
Jan 21, 2010 | Minolta DiALTA Di181 Printer
Minolta Di181 C1300 Service call
my copier is minolta di 181 it shows c1300 .how can i repair this problme? thank you.
Dec 17, 2008 | Minolta DiALTA Di181 Printer
Minolta dialta di181 c1300 error
Solution:
Jul 30, 2008 | Minolta DiALTA Di181 Printer
Error code 1300
THIS ERROR IS CAUSED BY POLIGON MOTOR OF THE LASER SISTEM. IF YOU CAN GET TO IT, JUST OPEN IT , LUBRICATE DE SHAFT AND YOUR PROBLEM WILL BE SOLVED. GOOD LUCK.
Mar 03, 2008 | Minolta DiALTA Di181 Printer
59 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
