Question about Konica Minolta Bizhub C300 All-In-One Printer
KONICA BIZHUB C300 ERROR C-5357 - Konica Minolta Bizhub C300 All-In-One Printer
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
herminio_hal
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Posted on Jul 09, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Error code C-0211 Konica Minolta Bizhub
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} C0211 :Bypass Lifting Motor Failure
Can anyone send me a firmware for Konica Minolta Bizhub C300
Its size is larger than 20MB but i will try to send you the link.
Mar 06, 2015 | Konica Minolta Bizhub C300 All-In-One...
How to rest a C3452 error code on a minolta C300
try a trouble reset turn the machine off hold utility/counter power machine on select trouble reset reboot machine
Aug 17, 2014 | Konica Minolta Bizhub C300 All-In-One...
Error code c-5357 on a bizhub c250
Left rear looking at the copier from the front. installed at a angle. one below is installed horiz.
Jun 11, 2014 | Konica Minolta bizhub C250 All-In-One...
Printer status report printing on each print in konica minolta bizhub c300
Printer status report, you can turn this off simply go to Printer properties check there.Check in printing preferences option.Also check in your Microsoft Office setting.Printer report printing is turned on simply turn it off.
Jan 10, 2012 | Konica Minolta Bizhub C300 All-In-One...
How to configure bizhub c300
can you check the protocal settings in printer properties
Dec 28, 2011 | Konica Minolta Bizhub C300 All-In-One...
What the Bizhub C300 Error C-5357 mean?
Seems Like its an Internal Error Issue Contact The customer support
May 05, 2011 | Computers & Internet
Bizhub C300 error C8103
To improve paper-feeding in the paper take-up section of the document feeder some adjustments have been newly made. Please ask a technician for this updates, but the error code suggest binding in the lift motor (may need to be replaced) or the lift plate is not producing enough pressure.
Jan 15, 2011 | Konica Minolta Bizhub C300 All-In-One...
What are codes F-34 and F-35?
These are heat sensor abnormality error codes in Konica Minolta 7222/7145/7135/7235/7228 models.You did not mention the model.
Oct 04, 2010 | Konica Minolta Bizhub C300 All-In-One...
Konica Minolta Bizhub C300 All-In-One Printer Logo
501 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
