Question about Exercise & Fitness
Treadmill motor drive belt
Where can i buy a drive belt for a reebok 2.2 edge treadmill, ithink the one on is stretched .thanks.
    Top Expert:
  • 12,223 Answers
Dear Sir:
Go the www.ftinessrepairparts.com or www.gymparts.com or www.treamillspartszone.com or www. treadmillsdoctor.com
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Posted on Feb 18, 2012
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
bwinton
  • 83 Answers
SOURCE: treadmill belt slipping
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem.
Posted on Apr 30, 2010
bwinton
  • 83 Answers
SOURCE: the belt is sticking on my treadmill reebok TR3
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
maxtreadmill
  • 832 Answers
SOURCE: Reebok treadmill
Hi James
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
Posted on May 24, 2010
SOURCE: treadmill kph to mph
No need to take console apart, power up the treadmill, take the safety key out then hold down the start button and the incline down button at the same time then insert the safety key. You'll now be able to toggle between KPH and MPH by using start button
Posted on Jun 15, 2010
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
Thumping from motor reebok treadmill
Seem like your front roller bearings are knocking. Remove the drive belt. Turn machine on. Replace roller if noise goes away with drive belt off.
Jan 02, 2014 | Reebok Competitor RT 5.1 SpaceSaver...
Hi, I have a Reebok Fusion treadmill and lately
LUBE THE deck belt,+rollers bearing front and back. test the drive belt motor, and replace the belt if necessary.
However if the problem persist, TIME to replace the deck belt
God bless you
Jul 31, 2013 | Exercise & Fitness
Will a reebok rodger black motor drive belt fit a reebok 2.2edge treadmill
Dear Sir:
Most of the time, can be fit in reebok 22.edge treadmill.Otherwise you can adjust the main motor and puller for to fit.
sincerely. God bless youm
ernesto cuadra
Feb 17, 2012 | Reebok Exercise & Fitness
I have a reebok es 8000 treadmill for 2 years now. it slips at high speed. it feels like the belt is not grabbed very well. thanks. andrew
2years take hood off check your drive motor belt if you find a bunch of dust your belt is worn or on it way out.
Mar 09, 2011 | Exercise & Fitness
When I power up my treadmil the belt does not move. If I step on the side the belt would then start to move until I move my foot.
In order of most likely cause. 1) Worn motor belt needs to be changed. Rear roller bolts need to be tightened as the walking belt has too much slack(2-3 inches lift on the edge of the belt in the middle on each side) 3) the nylon pulley on the front roller is slipping and a new roller is needed.
Oct 03, 2010 | Reebok 8050 ES Treadmill
Squeaking noise from tread
usually when a treadmill begins to make a squeaking sound it means that the belt needs to be lubricated. Try Treadmill Belt Lubricant available at Canadian Tire for $10.99 and is good for Reebok treadmills.
Aug 06, 2010 | Reebok Exercise & Fitness
Hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
May 14, 2010 | Reebok Exercise & Fitness
Reebok 8050es treadmill walking belt has started slipping/skipping. It has been oiled and it is 2 years old.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
May 05, 2010 | Reebok 8050 ES Treadmill
Replacing drive motor but can't get belt back on
Sometimes you have to loosen the drive motor put the belt on then tighten it up.
Mar 14, 2009 | Reebok Exercise & Fitness
Exercise & Fitness Logo
151 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
