Question about Ricoh Aficio 450 Copier
Fusing unit is not set properly - Ricoh Aficio 450 Copier
  • 313 Answers
This is a common problem on older ricoh with high counts the unit has a connector at the back to receive the fusing unit the connector on the fuser may have bee bent out of position and is therefore not contacting the unit correctly check the fuser connector is not damaged. also if there have beed jams sometimes paper can get stuck in the contactors also check in the receiving contact that the unit is not knocked out of place.
Posted on Feb 17, 2012
Ricoh mpc3500 fuser unit setting error
Most common problem is the electrical connector on the fusing unit or the connector that the fusing unit connects to inside the machine is broken. So when you push the Fusing Unit in to the machine the connector moves out of position and doesn't connect properly.
Aug 01, 2016 | Ricoh MPC3500
turn the printer off and reinstall the unit after it has cooled off (30 minutes). Then open cover B and D. Remove the fuser unit, then reinstall it properly. Close covers D and B. The error clears automatically if the fuser unit is properly installed.
If the error is not cleared, the fuser unit is out of order. Replace it with a new fuser unit.
Nov 19, 2007 | Ricoh Aficio AP3800C Laser Printer
White-rodgers 1f80-261 thermostat: Set to heat, "flame icon" appears but no heat and no fan. Thermo doesn't click when adjusting temperature. Set to fan,there is no fan.?
There is a 3 amp fuse in the main circuit board. If this fuse is bad ,nothing will work but because of the batteries in the thermostat it will lead you to believe that the unit is working properly,however, it is only showing you what is supposed to be. Replace the fuse and everything will work.
Oct 17, 2015 | Thermostats White Rodgers 1F80-261...
Ricoh sp c830dn running transfer paper for tshirt transfer. the toner is not adhering properly. poor transfer and ghosting. have tried various paper settings such as thick and special. no help have heard...
If it works fine for paper but not this application the machine is not designed for what you are using it for. You will damage the fusing unit. When it does not properly fuse the image the heat is insufficient and thus it does not transfer the image properly. Use the thickest paper type for best results.
Oct 09, 2013 | Ricoh Aficio Office Equipment & Supplies
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
Error c3921 konica minolta c451 error c3921 not known what to do
C3921: Fusing sensor wire breaks detection (Center of the heating roller)...
• At the warm-up stage, the heating roller
thermistor/3 voltage does not decrease by
predetermined steps (temperature rise)
within a predetermined time.
Check the fusing unit for correct installation
(whether it is secured in position).
Check the open/close operation of the
upper right door.
Check the fusing unit, IHPU, PRCB and
REDB for proper connection and correct or
change as necessary.
If that check still give you error code 3921
Change fusing unit
Mar 16, 2009 | Konica Minolta bizhub C450P Laser Printer
Operation light and timer light blink 5 times?
I don't know if this is the proper technical solution or not but my unit was having the same issue. I cleaned it checked fuses made sure the cover was properly in place and nothing worked. As a final thought I went to the home fuse panel and tripped the breaker for the unit, waited about 30 seconds and turned it back on. I did this with the unit set to off. When I came back and turned it on, it is working properly with the operation light solid red.
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Ricoh AP3800 COLOUR Laser Printer
SC 556 Pressure roller fusing lamp temperature fluctuation
The pressure roller
temperature changes by
±20°C or more in one second.
This occurs three times in one
minute or two consecutive
times.
• Loose connection of
the pressure roller
thermistor 1. Check if the fusing unit is properly set
and connected to the main frame.
• Loose connection 2. Check if the pressure roller thermistor
connector is firmly connected.
between the fusing
unit and main frame
3. Replace the fusing unit.
Nov 17, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh MP 2510
Fuser installation error. Fusing unit set error. Remove the fusing unit out of the machine and reinsert it. It isn't seated in there properly. Once you do that the error code will go away.
Sep 15, 2008 | Ricoh FT5832 Copier
Service code 546
SC 546 Heating roller
fusing lamp
temperature
fluctuation
The heating roller temperature
changes by ±20°C or more in
one second. This occurs three
times in one minute or two
consecutive times.
the thermistor
• Loose connection
between the fusing
unit and main frame
2. Check if the heating roller thermistor
Aug 19, 2008 | Office Equipment & Supplies
Ricoh Aficio 450 Copier Logo
238 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
