My Pioneer amplifier VSX-d512-s is coming up with the error message OVERLOAD and then immediately switching off. Has worked consistently for four years, this is the first problem
  • 1 more comment
  • The Soundman Nov 10, 2008
    Same thing, only happens when being fed a dolby digital signal. Other sources such as interntal FM tuner and 2 Channel audio work fine. Just happened while watching a movie.
  • Anonymous Dec 12, 2008
    I had the same problem with my technics sa-ex800, when I had both a and b speakers on I would try and go to pro-logic sound. I would get an error message. ( this was because I had the b set of speakers still on. I did not have a middle or surround speakers hooked up. the unit would give me the same comment yours did. The only way I could get rid of it was to unplug it for a long period of time.
  • repetersen Jan 24, 2009
    I have the same problem - just happened today. I had plugged in my Ipod, and noticed the sound was very low - i had it on max sound, and could only just hear it. Then it switched itself off and came up with the error message - OVERLOAD
  • 4 Answers
Sounds to me like a thermal shutdown. If it's no longer under warrenty, try opening the housing and spraying the inside with compressed air to free up any dust. Dust acts as an insulator and doesn't allow the heat to dissipate.
Beyond that, I'm not sure what else could be done without a service manual.
Posted on Oct 26, 2008
I have a pioneer vsx 07 11 and it says amplifier error
You see, the error message is coming from the power protection circuit which is constantly monitoring current being drawn from the receiver power supply. When the current exceeds the trip level it shuts down and give the error message.
power amplifiers has been shorted and the output transistors (one or more) have gone into breakdown and causing the excessive current drain. This will happen even though the speakers may not be connected to the amp outputs.
Jun 05, 2012 | Pioneer Audio Players & Recorders
Display message "DSP NG"
Hi pay attention to do all interconnections right
You can get help dowlowding a low cost service manual at link below:
Have a nice day and Good luck
Feb 21, 2008 | Pioneer VSX-D511 Receiver
Pioneer amplifier vsx-d512 overload message
This indicates the audio output stage in the receiver is loading down and triggering the overload protection circuit to kick in. Check the speaker wires for shorts, if okay! you will need a professional to assess the cost for repair.
Mar 31, 2012 | Pioneer Audio Players & Recorders
Pioneer vsx 405 overloading whenever it turns on I checked the speaker wires and they are all OK.
vsx405 came error dc protection chacked all power transistors c2500 ,a1948 all ok i was disconnect dc detector wire then ok after few minutes one pair burned with c945100 ohms resistors that time not fix heat sink then all replaced power on error overload with speaker and without speakers also coming error disconnect ol wire no chang pease help any expert amplifiers thanks
Oct 27, 2011 | Pioneer VSX-405 Receiver
My pioneer amp vsx d508 reads overload.what to do?
Sounds like a bad amplifier IC.
Unhook all speakers at the back of your pioneer. turn it on and turn down the volume. If it's no longer in overload you have a bad speaker or speaker wires touching somewhere.
If its still in overload it's prlobley a amp IC and will cost between $25-$60 just for the part if you can replace it yourself.
Dec 27, 2009 | Pioneer VSX-D508
Problem with pioneer vsx-916 av receiver
Be sure you have proper impedance with both sets connected. Some units have a selector switch in the back of the receiver to set the proper bias. ...accordianman
Jan 21, 2008 | Pioneer VSX-915 Receiver
The best way to do this (if you haven't done this already) is to enable the Dynamic Range Control. This neat little setting makes the difference between loud and soft to be not so much, making soft sounds (like talking in your case) louder and something like explosions not so loud. This is also called Midnight Mode on some receivers. To enable this setting, grab your remote and turn the receiver on. Press the "Receiver" button, then hit the left arrow on the remote until you see something along the lines of "Dynamic range control" pop up on the LCD (should be the 8th setting). You probably want to set this to "Max", but you can also select "Mid" if you find that Max does too much.
If this still does not work, you can bump up the relative volume of the center channel a bit (or a lot of bit). Hit the "Standard" button on your remote, then "Test Tone" until "C" or "Center" comes up on the LCD. Then hit the "Level +" button a few times, making the center channel a little louder. Listen to it a while and adjust it to your liking.
The combination of these two settings should get you where you want to be. By the way, do a search on your favorite search engine for something like "manual Pioneer VSX-D512" and you should be able to download a manual from somewhere (it looks like Pioneer no longer hosts the manual on their site). Hope this helps!
Dec 19, 2007 | Pioneer VSX-D511 Receiver
Pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Aug 03, 2007 | Pioneer VSX-D511 Receiver
488 people viewed this question
