SOURCE: my philips streamium will not load cds
hey this happened to mine. I contacted phillips and as it was still under warranty and they collected it, fixed it and returned it within a week. do that and see how you get on
SOURCE: Streamium WAC 7000 The base station is showing 'no
No solution but I have the same problem, looks like we are on our own with this one, have you asked Philips, I did about an hour ago
SOURCE: wac 7000
Hi, I had the same problem when upgrading to windows 8.
My solution was to load the original software on then remove it through programmes and features I believe the windows registry will still hold some of the older registry files needed for it to work. I then went to the Philips site and download the software for a later model I chose the WAC7500 system as some of the newer models require a activation code.
P.S Don't know if this might be part of the solution as well, when the original software was installed I did try to get it to work with the programme compatibility modes before uninstalling.
