Question about LG Vacuums
User manual for lg cyking dx v-ca711ceu it will not switch on no suction only 3 beeps when u try and press auto/min/max the filters have been cleaned
2 Suggested Answers
mnwarfield10
  • 452 Answers
SOURCE: My vacuum has no suction, and the "sbag" light
hose is blocked or change filters .
Posted on Jul 14, 2011
My Electrolux VC model code ZUA3830PT 2100W(max),makes a gurgling sound though the suction is still excellent, any thoughts? Any ideas?
sounds like something is stuck in the unit . use some kind of wire to see if you can fish anything out .
Nov 22, 2015 | Electrolux Vacuums
Rainbow vauccum D4C model
I think you made mistake of connections when reassembling the unit or place motor in wrong direction. Please open it again, if you opened it before, and check above said hints.
Sep 18, 2008 | Rainbow Vacuums
Model c87-vc-b lost suction despite on max setting, no blockage.
Yes, if you have not cleaned or replaced the filters, do that. clogged filters will kill the suction.
Apr 25, 2015 | Vacuums
Hoover duros no suction
you must see any clogged from Hose, or nozzles, and clean, or repair.
Will be a good idea tha yur use user manual, or download from the Hoover.com and proceed according.
God bless you
May 27, 2012 | Maytag Hoover Duros S3590 Vacuum...
I need an instruction manual for a EUROLAB robot vacuum cleaner Auto Cleaner Intelligent Floor Vac please
I have a Eurolab and I can give you a couple of tips...
Spot = concentric circles from a start point and will continue for 4mins
Clean = will clean until battery runs out then go to base.
Max = will clean until battery runs out and then return to base, charge and go again.
If you interupt any of the settings you will need to manually return unit to charger (either by picking it up- or turning it off on the unit - then turning it on again while holding down "Max" on the unit). It will then find its way home. The two different settings on the seperate little room divider are about how big the doorway distance is ie 1 metre or 4-7 metres (somethinig like that) to prevent it going into a sep room. There is a little filter that needes to be cleaned 1 or twice a fortnight - just to help with suction. The auto settings on the charger unit should be self explainatory but I just set mine off in the morning while I am doing other things and haven't go around to setting it yet. I am very happy with mine and my floor has all of those loose bits gone. I empty the pod weekly.
You can't make it go back with the remote - or if you can it is not mentioned in the manual and I haven't worked it out yet.
I hope this helps.
Cheers
Brittany
Nov 22, 2011 | Vacuums
Has no suction
1. Remove dust collector compartment/s. Look for any filters, remove and clean. (Make sure you DO NOT clean filters with water.) Take filter/s outside and "slap" them against a flat surface. (Filter will be very messy to clean)
2. Replace all filters and compartments.
3. Also try using a wire hanger and try to reach as far down the hose as possible to remove any obstruction/s.
Note: Clean vacuum filters frequently to ensure proper suction.
Feb 10, 2011 | Bissell 3920 Bagless Upright Vacuum
My dyson d70 won't pick up efficiantly, i have been hoovering plaster up previous to this. i have lost my user manual and can't remove the fillters to clean them.
Plaster dust is very fine and can get into the motor. Clean every part of the suction system, I've seen them be full of plaster pieces blocking the flow. Wash or replace every filter, dry before trying again.
Jun 06, 2010 | Vacuums
SpotBot: all lights flashing!
Per the manual, periodically you should clean the rubber lining in the dirty water tank(it comes out). I found mine a little dirty, but after cleaning it, it solved my 'all lights flashing' problem.
Aug 07, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Vacuums Logo
170 people viewed this question
Top LG Vacuums Experts
Think Crucial
Think Crucial
Ed Mac
Are you a LG Vacuum Expert? Answer questions, earn points and help others
