Question about Toshiba Computers & Internet
How to by pass boot device menu at startup?
Im using Windows 7 Professional 32 bit and everytime I start the computer I get the Toshiba boot device menu selection and I have to chose which device to boot from eg hard drive or cd/dvd, etc before Windows starts.
  • 3 more comments
  • falconglider Feb 17, 2012
    Thanks but I have already done that.
    Thanks but I have already done that. Now the keys on the keyboard are behaving erratic at times eg they dont work or they do something completely different. Also frequently when I click START with the cursor it doesnt work and I have to press the SPACEBAR several times to lock START in to be able to make it work. I reinstalled Windows 7 but it didnt make a difference.
  • Michael Green Feb 18, 2012
    Does your laptop work with XP or Vista? Not all Computers are able to work with Windows 7. I don't know what laptop you are using but If you carried out an upgrade to Win 7, I have to believe that you used the compatibility checker before you installed.
  • falconglider Feb 19, 2012
    I am using Windows 7 Professional 32 bit which came pre-installed on the laptop which is a Toshiba Satellite L500 that has 4GB RAM with an Intel Core 2 Duo CPU.
    I re-installed Windows 7 from the Toshiba Recovery Media that came with the laptop, thinking it might fix the problem but to no avail.
    It even started behaving erratic at once stage, when I was in the BIOS but its stopped that now and now seems to be bypassing the Boot Device Selection menu which I wanted at the start. But its still be having erratic as detailed before.
    Thank you for your help. I ended up dismantling the laptop today which I must say was a breeze on this type of laptop. The connection between the touch pad and the motherboard appeared to be loose in that the ribbon was not clipped in. This could explain the intermittent erratic behaviour I was having. So far its behaving normal so I'm keeping my fingers crossed that the problem has been solved. Thanks again for your help.
  • 3,799 Answers
On boot, press F2 and go to the Boot section of the BIOS then select the correct order for booting.
Posted on Feb 17, 2012
Toshiba laptop restarting
The loop on your Toshiba Satellite laptop refers to the computer not booting properly.
During the loop, the computer will try to boot the Windows operating system and keep restarting over and over again.
This is not a hardware issue with your Toshiba Satellite A106.
The issue resides in the startup files on your computer's hard drive.
You can fix this by running a repair tool that comes with your Windows operating system.
This repair tool will fix your startup disk and allow you to get your computer back up and running.
Insert your Windows 7 installation disc into your computer's optical drive.
Start your computer and wait for it to boot from the install disc.
Choose your language from the menu and then click the "Next" button.
Click "Repair your computer" from the menu.
Choose the operating system you are using and then click the "Next" button.
Click on the "Disable Automatic Restart On System Failure" button to disable the startup loop.
Click the "Startup Repair" tool from the menu and wait for the computer to fix your startup disk.
Wait for the computer to finish repairing your startup disk and then allow it to restart automatically.
Wait for the computer to boot correctly to your login screen.
Hope this helps
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
Oct 23, 2012 | Toshiba Satellite M35X-S311 Notebook
How do I make my lexmark p6350 compatible with my toshiba windows 7
Use the Vista driver in Windows 7. Before downloading the printer driver, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below to download the corresponding driver for your operating system:- Lexmark P6350 Driver for Microsoft Vista 32 bit and Windows 7 32-bit- Lexmark P6350 Driver for Microsoft Vista 32 bit and Windows 7 64-bit
Simply follow the steps on your computer screen to complete the installation.
Feb 27, 2012 | Lexmark P6350 All-In-One InkJet Printer
It seems that the driver to print did not install. i can fax, copy and scan but not print. message - no compattable printer installed. i did download it from the web aswell. im having an hp620 notebook...
It could be a printer driver issue. Try to uninstall your existing Lexmark S405 printer driver from your computer. On your computer, go to Start menu > Programs > Lexmark > S400 Series > Uninstall. After the uninstall process, reboot pc when prompted.
When your pc turns on, go to Start menu > right-click on Computer > Properties. Take note of the System Type (32-bit or 64-bit).
Use the links below to reinstall the printer driver: - Lexmark S405 Driver for Windows 7 (32-bit) - Lexmark S405 Driver for Windows 7 (64-bit)
Jul 24, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My toshiba laptop satellite model L650 windows7 installed is 64bit, can i reflace it to windows7 32bit?
Hi and Welcome to Fixya
Yes, you can change the operaitng system to Windows 7 32 bit. All you need to have is the licensed version of windows 7 32 bit. Boot upthe computer from that disk by pressing F12 key when you turn on the computer. Select the ODD drive to boot the computer to the windows 7 disk then you are good to go.
Thank you for using Fixya!
Feb 21, 2011 | Toshiba Computers & Internet
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet 3050 Printer
It is taking about 30 minutes, no joke, to print one page. There are long delays and then it seems to do a line and then another delay. This just started today which is a surprise as the printer has been...
Try HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP DeskJet F380 All-In-One Printer
My printer will not print black ink i just changed 3 cartridges
Oct 27, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My D7160 cuts the bottom part off of every photo. How do I fix this?
Oct 27, 2010 | HP Photosmart D7160 InkJet Printer
Will not print. Have to power off and then power back on for printer to start.
Oct 27, 2010 | HP LaserJet P2015dn Printer
Computers & Internet Logo
222 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
