HI, Does anyone know a clearance for a Konica Minolta Bizhub C35 with error code 0F52, thanks
Yellow Toner Sensor malfunction. Check connectors on PRCB, inspect/disassemble/reassemble/reinspect yellow toner sensor assembly, or possibly replace PRCB.
Source: service manual.
Credentials: I am having this same code right now.
Posted on Feb 20, 2013
5 Suggested Answers
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Pls help on how to clear error 0310 on bizhub c20 i have checked all the connection and my print head is ok what next shuld i do to remove this error pls is very urgent thanksa
You didn't say what make of printer it is. Error codes vary from printer make to printer make. Your best bet is to do a Google search for ERROR CODE 0310 NAME (NAME=name of printer).
If It's a Konica Minolta read the link below:
Konica Minolta Bizhub C35 Error Codes
Feb 17, 2016 | Office Equipment & Supplies
How do i fix error code 13DD ON KONICA MINOLTA BIZHUB C35
The counter data on one card does not match counter data on a different board did some one try to reset the counters to make the machine newer???? Need to get tech out to try and rewrite the firmware,
Jun 30, 2015 | Konica Minolta Bizhub C35 Multifunction...
ERROR CODE CALIBRATING
Might require having the firmware up graded get a konicaminolta tech out to up grade the firm ware from a secure konicaminolta web site.
Jun 06, 2014 | Konica Minolta bizhub C351 All-In-One...
Konica minolta bizhub c35 black toner being recognized as empty
sir/mam replace the cart then might have gotten a bad one from the store
Mar 11, 2014 | Konica Minolta bizhub C35 Black Toner...
Bizhub C35 error code 0F54
Cyan (Blue) Toner level sensor error, using OEM toner???? or third party?
Jan 31, 2014 | Konica Minolta bizhub Office Equipment &...
Bizhub C35 misfeed error
This video will show some of the most common causes for Bizhub C35 misfeeds
https://www.youtube.com/watch?v=Sbo0gon8EIY
Feb 26, 2012 | Konica Minolta bizhub C351 All-In-One...
340 people viewed this question
k24674
jasbo
jasbo
