Question about E-Machines Computers & Internet
Charging problem of emachines e725
My laptop is taking charge upto maximum 20%. Then it wont take charge unless it shutdown. i ve changed battery, adapter. still m facing same problem..
map9966
  • 2351 Answers
SOURCE: Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Posted on Mar 14, 2008
SOURCE: Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Posted on Aug 25, 2009
SOURCE: Emachine battery won't take a charge
how long do you charge a battery for an emachine e525?
Posted on Nov 11, 2009
  • 1481 Answers
SOURCE: My Dell 5160 laptop slows down with the AC adapter plugged in.
try running ur laptop using the adaptor without the battery in it's place and run it with just the battery...note the difference....it may be a power surge/short issue....some times the battery is supplying power along with the adaptor to the notebook and the power circuit in there is not able to take dual power....check your power options setting in Control Panel...
also do this
clean ur system use Tuneup Utility get it from my website Dowload page
www.sureshayyar.110mb.com
use all the tools and option in that tool...the best is 1n Click Maint in there .....it fixes all ur issues...
Posted on Dec 29, 2009
SOURCE: Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Posted on Jan 09, 2010
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? ' eHow.com http://www.ehow.com/way_5261076_long-charge-new-laptop-battery.html#ixzz1GTAFQEz9
    Mar 13, 2011 | Acer Computers & Internet
    Acer netbook battery cannot reach 100% charge?
    As rechargeable batteries age they build up what is called a 'memory' or a 'charge memory'....
    Let me explain how this works...you have a new battery and you run your laptop normally until it hits 15% charge then you charge it up and use it again until about 15% then charge it again....with the charge only dropping to 15% the battery builds up a 'memory' of that over a period of time (usually over at least a year up to a couple years) and then your battery's maximum capacity is no longer 100%. Same thing happens if you dont charge it fully each time, after a while it becomes incapable of taking a full charge.
    What you can do to stop that in the future....when you get a new battery every now and then run its charge down to 1% then charge it to maximum. By doing that on a regular basis you help make sure the battery remembers its full charge capacity.
    Feb 19, 2011 | Acer Aspire One 521 532H 533 D260 NAV50...
    Hello, i have an eMachines 525 notebook; from 2
    Try another battery, known to be working fine,in your laptop. If the problem still persists, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
    Sep 03, 2010 | Acer eMachines 520-2890 Notebook
    I have a new emachine e725-4520 laptop. Backlite
    Hi, what you can do is to replace the power inverter that's located in the front bezel of the screen just remove the front bezel and locate the inverter. If you want to replace it just buy a new one in a computer part store, or online at www.yahirselectronics.com. Hope this helps you.
    Apr 07, 2010 | Computers & Internet
    My aspire 5740 showes 81% available but not charging, checked all power lines etc on balanced power. Bought laptop 3 weeks ago till today it charged up
    Hi
    Dont be panic. Your laptop has absolutely no problem.Your manufacturer had set a 80-20 policy for the laptop battery charging such that the battery wont be charged to 100 percent but it will charged only upto 80 percent. The makers of the lap are doing this because to give good life to the battery.You can change it by going into the power options inside control panel.
    Mar 23, 2010 | Computers & Internet
    Compaq nx 9020 battery charging problem
    Damaged battery or internal circuit problem it is hard to to say. Bring your laptop to a repair shop. They can check the battery and tell you what the problem is.
    Dec 04, 2008 | HP Compaq nx9020 Notebook
    Battery proplems
    I would advise getting a new battery as some batteries go bad
    Jun 14, 2008 | IBM ThinkPad R52 Notebook
    Computers & Internet Logo
    405 people viewed this question
    Top E-Machines Computers & Internet Experts
    Matthew Spark
    Matthew Spark
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
