Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Saeco Royal Digital Plus Coffee Maker, Espresso Machine
Hi.... the coffe comes out really watery even if a change the ground or the dose
Go into the menu and reduce the amount of water the machine pumps through
thanks
Coffee fix
Posted on Nov 01, 2008
The flow of coffee is really slow
try to large the granulates the cofee ground. inside the coffe tank is the numbering disc. try to put him exemple: is at 5 put it to 7 and make 3 coffe then the flow of coffe will go faster
Sep 29, 2014 | Saeco Spidem Villa Espresso Machine
When i make a cup of coffee with my kuerig coffee maker my coffee is coming out with coffee grinds though it. how can i fix this problem?
Your coffe may be ground too finely for your maker.
Is your coffee maker flat-bottom or cone shaped? Or is it a french press?
Your coffee needs to be ground according to the brewing method. Too coarse and it will be watery, too fine and it will be too dark, or you might get grounds.
May 06, 2011 | Vacuums
My coffe comes out too watery. the grinder is set at max (fine grid) is there another setting for the water? or to maximize coffee grinds?
Remove all the beans in the grinder chamber, then remove the screws and slowly lift the chamber about 1 inch high, then turn adjustment knob 3 numbers back and lower chamber making sure the gears on the bottom line up.
Feb 28, 2011 | Saeco Incanto Classic Espresso Machine
Very little water comes through...small drips...enough to get the grounds wet but not enough to make coffee.
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 22, 2010 | Krups Small Appliances Espresso Machine
Waret Pucks
Hi There are 2 problems that can cause a watery puck. 1. Like EsWorld said, If the grinds is too coarse it leaves room for more water and you get a watery puck. 2. But if your grind is like a grain of salt, the you don't have enough coffee going into the brew unit, and this leaves room for extra water. To fix this, there is a lever on the top center of the door. The lever will increase the dose if pushed towards the back. DON'T push the lever to the full back position. This could cause an over charge, which could cause the brew unit to dump the ground coffee with out making because it could not compress the charge, or it could break the brew drive. 1 click back from the full plus is fine and will give a great shot.
Jun 03, 2009 | Saeco Royal Professional Espresso Machine
Coffee watery
Setting your dose at max and grinder at finest is not good. This means that you are asking the machine to grind coffee really fine, and then dose maximun amount which can lead to the grinder getting clogged. If you are looking for stronger coffee, it is best to have several shots that one that has too much coffe and too fine. For stronger espresso, use less water instead of more coffee. Two shots of 2 oz. espresso (made with 7 grams of coffee) are more flavorful & sweeter than one shot of 4-oz. espresso made with 14 grams of coffee which could clog your grinder and door/channel. At this point, you need to clean the grinder ( inlcuding the door/channel). I suggest you have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Jun 15, 2008 | Saeco Caffe Charisma Espresso Machine
Espresso is dark and rich at first; then shifts to water
This is suppsed to happen, every espresso machine out there on the market does this.
All the taste for the coffe comes in the first couple of seconds and after that it gets less and less.
So the problem is not that it gets lighter and lighter, but that you dont get enough taste in the start of the brewing.
And this can be caused by alot of things.
Bad beans?
Not set the grinding to fine?
it will not heat enought and thereby not get enough taste.
etc.
Apr 12, 2008 | Saeco Talea Giro Espresso Machine
Grind Not Fine Enough
First of all did you change the coffe brand, if you did this may explain the changes, if not then perehps the the mechanisem is worn out so take it to a service agant and he'll change it
Jul 10, 2007 | Gaggia Titanium Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
201 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
