Question about HP Laserjet Cp2025n Printer
What's your problem?HP Color Laserjet Cp2025n Printer -
I have a hp color laser 2025 there is a papaer jam error but i did not find any paper in rear door how can i solve this problem
Hi my hp 2025 laser printer is reading low memory error.....
the printer is printing simple text .....but full colour graphics ...am getting memory error.....how can you help.......
Posted on Jun 02, 2012
  • 624 Answers
SOURCE: Hp Color LaserJet 3500 Paper Jam
The only way to find paper remnants is to unplug the printer and inspect the paper path. It also helps to have a good focusing flashlight, skinny needle nose pliers, a can of compressed air (used sparingly) and a long thin probe. Your specific printer should be giving you jam messages with a location code as well. I?ve attached a link to an HP page containing a diagram of the 3500 paper path and the error code jam locations: http://h41206.www4.hp.com/webapps/IV3/node.iv?locale=en_us&prodSeriesId=315862&node=prodITRC%2FNL_HW_IPG_plakCLJ3500_EN_01_E%2FN1%7C6%7C9&prodTypeId=18972&serverId=1#src I solved this problem in my shops years ago by not letting anyone else clear jams OR insisting that any paper removed as a result of a jam is given to me. If any corners or pieces are missing I know what to look for and approximately where. Good hunting and please don?t forget to rate this post.
Posted on Mar 21, 2007
SOURCE: hp color laser 2840 paper jam
Quit eating your lunch.
Posted on May 21, 2008
DosHog
  • 168 Answers
SOURCE: 13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Posted on Jul 23, 2009
  • 52 Answers
SOURCE: My HP Color Laserjet 3600n had a paper jam. The
Your best method of troubleshooting is the manual sensor test as this is a generic paper jam error.
on your sensor tests:
0 = off
1 = on
A = TOP OF PAGE SENSOR
B = PAPER LOOP SENSOR
C = N/A
D = FUSER PAPER SENSOR
E = DELIVERY-TRAY PAPER-FULL SENSOR
F = FUSER PRESSURE-RELEASE SENSOR
G = MEDIA SENSOR
H = N/A
I = MP TRAY SENSOR
J = CASSETTE SENSOR
K = DOOR OPEN DETECTION SWITCH
L = DEVELOPING ESTRANGEMENT SENSOR - CLR
M = DEVELOPING ESTRANGEMENT SENSOR - BLK
N = MP TRAY MEDIA POSITION SENSOR
A-F are paper path sensors - you can toggle them and watch if they change from 0 to 1. If they do, the problem is not in that area.
G can have states from 0-7 each one representing a different type of paper - shouldn't have anything to do with jamming.
hope this helps. probably a tiny piece of paper or toner somewhere. could also be a torsion spring out of position on a flag.
Posted on May 10, 2010
SOURCE: paper jam inside HP Color Laserjet CM1312 MFP, not
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Posted on Oct 12, 2010
Hp COLOR laserjet 5500
Power off the device. Remove the new fuser. Ensure there is no debris or paper through the paper path (blow some air through it.. Ensure all the flags are neither broken nor in the wrong position. Reinsert the new fuser, ensure the covers are properly in place then power on.
Jul 09, 2014 | HewlettPackard HP Color LaserJet 5500n...
HP LASERJET 100 COLOR MFP M175a PAPER JAM
I suggest you some points like clear the dust in the printer, proper set paper in paper place, adjust the paper line etc..
If More Support visit this link. I hope solved you problem..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02622145&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=5076465
Jan 15, 2014 | HP LaserJet Pro 100 color MFP M175A Laser...
HP Color Laserjet CP2025n Load Paper
In XP, go to settings; control panel; printers& faxes; then left click your printer and select "Properties". Click the "Device Settings" tab and you should be able to figure it out from there, by clicking the trays and selecting "not available". I have that same printer and I just did it with mine so I know it can be done.
Jun 08, 2012 | HP Laserjet Cp2025n Printer
I get this error code in hp 1312 error cod 51.23 what can i do i wait your answer best regard
Turn power off. Unplug printer. open and close firmly every door, hatch, panel, and drawer. Verify all toner cartridges are full. Verify that no paper is jammed in the mechanism. Power printer back on.
Aug 20, 2011 | HP Laserjet CM 1312NFI Color Printer
HP colour laser jet CP2025. Prints colour on test sheet but not from pc. It was printing colour until wireless was installed - is there a connection?
Your driver is not sending color data. Either your driver is set to print in geayscale, or you are printing through a monochrome driver to the IP address of the CP 2025
Jun 30, 2011 | HP Laserjet Cp2025n Printer
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
59.co printer errar hp color laser jet 3500
This error is a developer motor error not related to any color. Check the back of the printer to make sure that there is no paper jam in the exit assembly. Reseat all cartridges and restart. If it still does not start then the developer motor is probably shot.
Mar 19, 2011 | HP Color LaserJet 3500 Printer
Problem in hp cp 2025 color laser printer that printer is giving error message "used black cartridge is in use error
This error typically indicates that the cartridge was moved (e.g. previously installed) from another printer to your printer. The error should not affect your ability to print. If you want to clear the error, replace the affected cartridge with a genuine HP replacement.
Aug 10, 2010 | HP laserjet Cp2025dn color Card Printer
Ghosting when using HP CP2025N
Bad drum unit poor fusing or paper type try to print paper type cardstock as type, this increases fuser temp and slows printer for better quality.
-Carl, please let me know if this helps.
Jun 25, 2009 | HP Laserjet Cp2025n Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
HP Laserjet Cp2025n Printer Logo
320 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
