Question about HP Pavilion dv2000z Notebook
Laptop no power
I plug in laptop, registers no power, click power button, no response.
  • HP Master
  • 5,660 Answers
Check the output of the AC adapter (Charger), or skip to check the DC Power Jack, first.
A) DC Power Jack:
The jack on the laptop that the AC adapter (Charger) plugs into.
IF, this is in reference to an HP Pavilion dv2000z series of Notebook PC, this is what the jack looks like not installed,
http://www.dcpowerjacks.net/catalog/index.php?main_page=product_info&products_id=1051
In the views of the jack, the pins and blade are on the Bottom of the jack.
They go down through the motherboard, and are soldered in place.
http://www.aaroncake.net/electronics/solder.htm
Scroll down to Step 5, and observe the Solder Joints.
IF, a solder joint, (Or more than one), is cracked, the DC Power jack will Not flow power to the laptop.
ALL power removed (AC adapter and Battery) see if you can gently wiggle the Center Pin, of the DC Power Jack. Using a non-metallic object is preferred.
See if the entire jack seems to move around.
ANY perceptible movement means a bad DC Power Jack, or solder joint/s.
Laptop is to be completely disassembled, down to the BARE motherboard in your hand. (No Processor, no Ram Memory, Nada )
This is a basic guide to DC Power Jack replacement,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
A) You can use a 25 Watt soldering iron, with a No.2 chisel tip.
Keep a damp sponge handy, if you do not have one in a soldering iron stand. Keep the tip CLEAN, and well tinned, at all times.
B) Use Desoldering Braid. (Solder Wick)
Works MUCH better than a Desoldering Tool. (Solder S-ucker Tool)
Unroll a small length. Flatten out a small length, around 2 inches long.
Lay enough of the tip of the Desoldering Braid, across the solder joint to cover it. Then lay the tip of the soldering iron on top of the braid.
Once the braid, AND solder heat up enough, the fine twisted wires of the Desoldering Braid will pick up some solder.
GO S-L-O-W.
If you overheat the solder joint, the copper circuit trace area under it, can lift right off of the motherboard. Bad times are ahead.
If you overheat the solder joint, the copper circuit trace area under the solder joint, can lose it's tinning, and CANNOT be re-tinned again.
Bad times ahead.
As soon as the solder starts to melt, and you see the braid has picked up some, remove the solder iron, and braid.
Allow the motherboard circuit trace area to cool down.
Then begin again with a fresh new piece of Desoldering Braid.
Cut the solder soaked section off.
Keep going back, until you have removed all of the excess solder that you can.
(Make take a few times, or more, to perform this, and allow the circuit trace area to cool down in-between )
There will be a skin coat of solder left behind. As you heat one of the pins, or the blade, pull up on the jack.
The pin, or blade, will partially come out. It will not come all the way out because of the other pins, or blade, is still soldered in.
Go to the next pin/blade, and heat it up. Pull. The pins, and blade will come out of the motherboard a little further.
Allow the circuit trace area to cool down in-between heating each pin, or the blade.
Keep going around until the jack is free.
You might have a skin coat going across the circuit trace hole.
That's OK, leave it.
When the new jack is installed, the pins, or blade goes against this skin coat. When the soldering iron touches the skin, the pins, or blade, will poke through.
Make GOOD, shiny bright solder joints. A dull, cold solder joint, will have you scratching your head.
B) If the DC Power Jack proves to be good, with the simple test of the device to see if it will wiggle, go to the AC adapter. (Charger)
The Center Hole in the plug that plugs into the DC Power Jack, is Positive. The outer cylindrical metal shell is Negative.
Positive (Red) probe lead to Center Hole, Negative (Black) probe lead to outside cylindrical metal shell.
Function knob set to DC Voltage. (If just a symbol, the symbol is a dotted line over a solid line. If more than one scale, set it to the 0 - 50 Volt scale )
You should be reading VERY close to 18.5 Volts.
Also have an assistant wiggle the Power Cord, and the cable from the adapter unit, TO the laptop.
An intermittent reading indicates a broken wire.
DC Power Jack, and AC adapter check out, the problem is the power controller chipset.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The power controller chipset is a power MOSFET.
Here are two examples used in a Lot of laptops,
1) http://html.alldatasheet.com/html-pdf/85156/VISHAY/SI4925BDY/183/1/SI4925BDY.html
2) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
When bad, generally the power controller chipset will burn up, and blacken.
Note that in both examples above, that the chipsets are in a D2PAK surface mount design.
The J leads are easy to unsolder, and solder.
Posted on Feb 18, 2012
  • joecoolvette
    joecoolvette Feb 18, 2012
    D2PAK surface mount,
    http://en.wikipedia.org/wiki/D2PAK
    HOWEVER, when soldering the new chipset in, use a Heatsink on each lead, as you solder it on the motherboard.
    http://www.radioshack.com/product/index....
    Power MOSFET,
    http://en.wikipedia.org/wiki/Power_MOSFE...
  • joecoolvette
    Forgot my manners,
    For additional questions please post in a Comment.
    Regards,
    joecoolvette
How do I register my Panera member card?
  1. If you are a new user and you've never used this card before, click on the button marked, "Register My Card."
  2. Indicate that you have a card that you want to activate by registering and click the button marked, "Continue."
  3. Enter your MyPanera Card Number and Registration code.
More items...
www.mypanera.com : Register to Activate a MyPanera Card
https://www.loyalreview.com/www-mypanera-com-register-to-activate-a-mypanera-card
Oct 25, 2016 | Computers & Internet
My toshiba satellite was working ok on battety when plugged in. Went dead. No lights no response to button
what do you mean by working on battery when plugged in.
If it was plugged in to power then it should run on Power not battery.
Suggest power adapter may be faulty and battery is now flat.
Also Suggest trying this - holding power button in for 2 minutes and then try power button again. in case it has locked up
Sep 23, 2016 | Toshiba Computers & Internet
I my plug in HP pavilion DV4T laptop, registers no power, click power button, no response.
if you are not getting any lights on the laptop when you turn on,,try checking the fuse in your plug or get your power supply checked out and also your battery.
Jun 08, 2014 | HP Pavilion dv2000z Notebook
Samsung laptop problems
try cold reset by removing the battery including power adapter then press power button for approx. 20 secs. then plug your power adapter then press power button again. press the numlock/ capslock button if there is response showing that your motherboard isnt dead yet. please check also when fan is running momentarily then suddenly stops then post another question here.
Dec 02, 2013 | Computers & Internet
I have an HP Pavillion dv1000, when I powerup my laptop. it seems that no response from my keyboard... even if I click the F10 button to check for the setup, seems no response...
this to has happened on my dell laptop but my problem at the time was that the plug in from the key board to the motherboard came loose and was not making contact if you can you can try to go into safe mode click on control panel then go to system click on device manager scroll down the list of items till you get to key board and mouse if there is a yellow question mark beside it double click on it then go to update drivers and see what happen then if that does not work try to roll back the drive if that fails it may be that the plug to the motherboard to the key board may have come loose best of luck to you
Apr 29, 2011 | Computers & Internet
Reset password cmos toshiba satellite A65-s1064
The only way to reset the cmos battery is to remove the battery from the back, open the bottom of the laptop and remove the button battery for 3-5 minutes. Replug in the battery and close up the case. Once completed, you can then create a new password.
Apr 08, 2011 | Toshiba Satellite A65-S1065 Notebook
Dear sir i purchesed new G42 460tu Laptop and i wanted to register my Laptop in Hp for better support and offers for the same which i bought it
Please open this LINK and follow the onscreen instructions to register your Laptop.
Let me know if you need further help.
Thanks for using FixYa.
Mar 06, 2011 | Computers & Internet
I want to register my laptop for waranty ps assist
Register it on this link:
https://register.hp.com/americas/flowPage/registration/index.do?execution=e1s1&cc=CA&lang=en
FYI, keep your receipt handy , you will need a copy when you ask HP for service.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 29, 2011 | HEWLETT-PACKARD ProBook 4520s
Computer is on when plugged in and will not turn off with the power switch. computer will boot up to sign in window but freezes with instructions to register windows but keyboard and mouse do not work at...
First of all you have a couple of issues..
The power button on those old systems don't allow for shutoff by power button when there is an issue, odd i know but I just had one in this week...
As for registering it sounds as if the system just went through a reinstall atleast more then 30 days ago.
Try starting the system with the disc in the drive, when the system starts up try clicking ESC button or F12.
that should allow you the chance to click start from disc and restart all over again.
Nov 08, 2010 | IBM NetVista PC Desktop
Hi, HP pavillion dv7 laptop. Went into hibernate mode but will not wake. Pressing power button does nothing. Hold power button for 5 to 10 sec does nothing. Plugging in power cord is not registered by...
are you running vista? this is an ongoing issue with that operating system. my best advise would be to totally disable hibernate and sleep on your computer by changing the power settings.
  1. right click on your desktop
  2. click personalize
  3. go to screen saver
  4. on the lower part, you should have change power settings there
  5. play around with it and disable hibernate and sleep
hope it helps.
Mar 14, 2010 | Computers & Internet
HP Pavilion dv2000z Notebook Logo
269 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
