Question about Aiptek Cameras
Aiptek Sd card compatible Problems - Aiptek Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Aiptek Master
  • 102,366 Answers
Some Aiptek cameras work with SD and SDHC cards, some work only with SD cards. If you have one of the latter, make sure your card is an SD card, not an SDHC card. The two card types are physically identical but electronically different.
If you need further assistance, please feel free to reply to this post. But be sure to specify the model of your Aiptek camera, as well as the type and size of your memory card.
Posted on Feb 17, 2012
Card error
Is this the card you always used, or did you recently buy a new card?
Because you can use MMC cards and SD cards. Most SD cards you now buy, even the 2 GB ones, are SDHC cards and they are not compatible with your camera.
You should try to get an SD card. They used to make SD cards up to 4GB, but as I said, now they already make 2GB SDHC, So look careful when buying a memory card.
If it was the card you always used, try to get all pictures from the card, using an external memory card reader on your computer. Then in the camera do a format, before you continue.
If it does not work, try an other card. SD that is.
Mar 01, 2014 | Aiptek PocketCam DV4500 Digital Camera
How to unlock sd card on Aiptek camera
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 31, 2010 | Aiptek Pocket DV5900 Digital Camera
Deleting files on HD720p Aiptek camcorder
You are not doing anything wrong. For some reason, Aiptek doesn't give you this option on the camera. You have to insert you SD card into a reader and delete it that way. Ya, I know, doesn't make sense. Also, a feature I hate is it does place your videos into one continuous file. Only video clips, so each time you stop then start recording, it creates a new file. Anyway, I've had my Aiptek since 10/2008 and no problems so far. Great indoor videos. Not too crazy about the still pictures though.
Dec 08, 2009 | Aiptek A-HD 720P Flash Media Camcorder
Recently purchased an Aiptek IS-DV. It has
Your problem has a very simple fix. The camera which you have is not compatible with SDHC cards. It will only work with regular SD cards.
Your camera is incompatible with the later SDHC specification at the basic hardware level and so cannot format the card which you have purchased.
Note that SD cards are available up to and including 4GB and SDHC start at 4GB so you're not the only person to have made this mistake. In practice there are very few devices designed to use regular SD cards which will work correctly with 4GB SD; Aiptek only designed and tested the IS-DV up to 1GB SD capacity (see page 48 of the user manual), so this is the effective limit to the largest capacity memory card which you can use, if you try larger capacity cards they will either not work at all or will make the camera operations sluggish and you also risk damaging the card itself so that it will no longer correctly format. Aiptek never released any firmware updates to improve the SD compatibility on your camera.
I'm sorry not to be able to offer any way to use your current SDHC card but at least I may have prevented you making another purchasing mistake. Please return the favour by rating my answer.
Nov 02, 2009 | Aiptek Pocket DV2 Digital Camera
I have a camcorder that says it has webcam capabilties, but i dont know how to use it or even find how to use it! the camcorder is the brand Aiptek the make is ISDV2.4 where can i find the webcam???
Install the driver software on your system. If you don't have it, you can download it from aiptek.com under the support tab.
If you have windows vista be sure to set the setup.exe compatability to windows xp before trying to install. (Right click on setup.exe, go to 'compatability' tab, set to windows xp, click ok.) If you already installed it on vista without setting the compatability just run the setup again and choose the 'remove' option, then reinstall it with the correct compatability.
Once the drivers are correctly installed a shortcut should be added to your desktop labeled "DV TS". You can open this to check that the driver is working properly. Be sure to have plugged your camera in through the USB port next to the SD card slot.
At this point if everything has gone well, then you should be able to select it as a video source in whichever Instant Message program you choose to use. Providing that program supports webcams.
-Refer to the IM program's help file for instructions on how to select a video source / web cam.
Jan 19, 2009 | Aiptek ISDV2.4 Flash Media Camcorder
SD vs SDHC Card in Aiptek ASDV2.4 Camcorder
No return the card before you open it and get a regular SD card! this card will not format in your camera! Please rate my answer!
THANK YOU!
Jan 15, 2009 | Aiptek ISDV2.4 Flash Media Camcorder
AIPTEK PROBLEMS
Do what I do- take out the SD card and transfer files directly to the computer without the camera.
May 20, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Will not recognize 16 GB SDHC Card - Help Please
I had a literally terrifying experience with Aiptek customer service.
I called up Aiptek to ask if it was possible to get my memory cards working. I have two 4GB SDHC PNY cards, which th ekid at target reccomended after loking at the back of the box.
I was told by aiptek tech support that PNY cards will not work in the A-HD camera.
When I mentioned that the box says it will take cards up to 32GB, and asked him if this was not false advertising. The representative became irate and started insulting me, using valgure language, and calling me a liar.
At this point I had enough of his abuse and yelled at him F.U!
What happened next is Truly Absurd and Outrageous!
The man behind the telephone at Aiptek told me he was going to send 5 guys to my house to assult me and my fammily!
THIS IS NO JOKE!
Jan 19, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Wont read sd card..screen shows card locked..card ok
There is a little slide switch on the side of the memory card. Good luck!
Jan 02, 2008 | Aiptek IS-DV2 Camcorder
Help
The camera should show up in Windows as a removable drive (like any USB thumb drive). From there all you should need to do is copy your mp3 files to the mp3 folder on the SD card in the camera (you will need to use a memory card as the internal memory is fairly small).
Make sure the file names are not very long or there may be problems getting them to show up in the camera's mp3 player.
Dec 28, 2007 | Aiptek IS-DV2 Camcorder
Cameras Logo
70 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
Greg Cann
Greg Cann
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
