Question about TallyGenicom 6312 Matrix Printer
How to reset setting on tally Genicom 6312 - TallyGenicom 6312 Matrix Printer
4 Suggested Answers
Techvisitor
  • 63 Answers
SOURCE: error on tally genicom 6312
found this on Tally Genicom's Website about your device.
Technical Services Note
MT6xx/T6xxx (All) Paper Motion Faults 11 May 1995
T645.039
If you are having problems with recurring Paper Motion Faults that don’t seem to stay
fixed by doing the paper motion sensor calibration, try the following:
· Check the back of the form along the left side to ensure there are no black (dark) areas
in the area of the tractor drive holes. (If there are, this is probably the problem. If not,
proceed on down this list.)
Clean the sensor on the upper left tractor then run the calibration routine again. If it’s
not better yet, continue.
With Tech Access ON, do the following:
Go into DIAG - Meters - Paper Motion and monitor the sensor reading with paper
installed and removed. If the reading with paper installed is in the 300 to 350 mVolt
range, change the sensor (even if it seems to run the calibration alright). A more
normal reading would be something greater than 600 mVolts for the MT691/6092 and
1000mVolts or greater in the 645/661. Don’t forget to recalibrate the sensor. If it’s
not fixed yet, try this next step.
Run a configuration printout and then do the following:
1. Clear the NV Ram (Tech Access feature ON)
2. Calibrate the Paper Motion and Paper Out sensors
3. Restore the configuration based on the print-out you just ran
http://www.tallygenicom.com/support/technotes/tnote/d5639.pdf
my site: www.techvisitor.com
Posted on Oct 31, 2008
  • 169 Answers
SOURCE: Our Genicom Tally printer fails to keep settings.
There may be a number of reasons for the 6312 failing to keep your settings, the first thing to identify would be that you have changed the settings on the printer and then saved these settings. If you do not save the settings to a menu / configuration they will be lost if the printer is powered off or receives a reset command.
Once you have made your settings changes, the settings can be saved in the following way;
Ensure the pritner is OFFLINE
Press Menu
Press Up Arrow until display shows Config Menu
Press Enter
Press Up Arrow until display shows Configurations
Press Enter
Press Up Arrow until display shows Save
Press Enter
Press Up Arrow until the Config Number Or Name appears that you want to save the settings to (Default is Confg 1)
Press Enter
Press Clear, to return to Offline mode.
If you save your settings you can then print a configuration report to see the values that have been saved, this can be done in the following way;
With the printer OFFLINE
Press the Menu key
Press any Arrow key until display shows Config Menu.
Press the Enter key.
Press any Arrow key until display shows Printer.
Press any Arrow key until display shows Report.
Press any Arrow key until display shows All Configs.
Press the Enter key and the configurations will be printed.
This should show your saved settings, try powerign th epritner off and back on again and again print the Congfig report to check the settings are retained.
If you find the settings appear to change when you print to the printer this will be caused by your print job, escape commands in the print job will take presidence over the printer menu settings.
You would need to check the host computer system to see what might be causing the problem; chack page size, fonts, ensure the correct printer driver is used etc on the system.
Posted on Jan 29, 2010
SOURCE: t6312
Tally Genicom 6312 is not printing PDF file.I have to print nearly 5000 pages of PDF file . How to get print in this printer. any seeting is there.
Posted on May 04, 2011
WHERE DO I GET RIBBONS FOR THIS UNIT
Contact Printronix in Irvine, Ca. Printronix took over Talley/Genicom and they support these printers.
Mar 13, 2014 | Genicom Tally 6312 632 Adp Lp1500 Network...
Sir, We have a Genicom 6312 L Line Printer. This printer is attached with UNIX (5.9) system. It was working fine till few days back. Recently we changed the Logic Card. After this the printer is not...
If the printer does not print from Unix via parallel interface, it may be nessesaey to set the BI-DIRECTIONAL setting within the Parallel interface settings to OFF.
Sep 21, 2011 | TallyGenicom 6312 Matrix Printer
I have a tally genicom 6312 printer which gives me hammer voltage 2 error what do i do
A high resistance coil fault has likely occurred in one or more of the hammer coils.
Note: this fault message will have been preceded by printing slow-down attempts associated with On-
The-Fly thermal monitoring of hammer bank temperature.
Check the hammer bank for defective coils.
If no defective coils are found replace the Controller Board.
Dec 31, 2010 | Tally T6218 Matrix Printer
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Our Genicom Tally printer fails to keep settings. The model type is 6312. What could be the problem?
Press Menu
Press Enter
Press Enter
Press Enter
Press Enter
Press the Menu key
Jan 26, 2010 | TallyGenicom 6312 Matrix Printer
Platen motion fault in tally genicom 6312
problem with platen sensor , clean the sensor with ipa still same problem change the platen sensor
Dec 06, 2009 | Tally 6312 Matrix Printer
How to reset the NIC to use DHCP
If you press the test button once on the network interface (a small black button near the network port) This should print out the network settings, you can then confirm the IP Address etc set on the printer.
I belive the defult setting on the network card is for DHCP= OFF, so if you default the network card you may not get the result you required.
The netword card can be set to defult by holding down the test button for more than 10 seconds. This should reset the network settings to factory defults.
You can unlock the menu on the 6312 by pressing the MENU and ENTER buttons and keep them held down for 5 to 6 seconds you can then access the menu.
The IP Address, Sub Net Mask and Gateway can be set via the control pannel menu on the pritner.
If the IP Address set in the pritner is valid for the network you should be able to get to the printers web page, you can then make changes to the pritners and network card configurations.
Mar 28, 2009 | TallyGenicom 6312 Matrix Printer
What is the similar to Epson printer DFX-9000 In other brands
This link contains Dot Matrix printers from various manufacturers. I believe your printer is a 24 pin printer:
http://www.superwarehouse.com/24_Pin_Dot_Matrix_Printers/c3/2525
Dec 16, 2008 | Epson DFX-9000 Matrix Printer
Error on tally genicom 6312
T645.039
Jul 01, 2008 | TallyGenicom 6312 Matrix Printer
TallyGenicom 6312 Matrix Printer Logo
201 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
