Where is the softner dispancer in samsung wobble 3d washing machine top lodder
  • 1294 Answers
SOURCE: softner remaining
Try diluting the softener, some softener are too thick. But first clean out the softenre tray, by pulling it out, or with a tooth brush. Do look into your user manual. Does water enter the soft tray, check this too.
Posted on Sep 08, 2007
SOURCE: washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Posted on Jan 16, 2009
Dissolu
  • 221 Answers
SOURCE: washing machine fabric softner problem
Remove the detergent compartment itself and clean it all up. Usually such problem is caused by blocked hole for softener. otherwise check coil continuity of the orange coloured water inlet valve
Update me about your progress
Posted on Jul 25, 2009
  • 96 Answers
SOURCE: the machine has stopped taking in the softner on a wash cycle
use the dounty balls thay work better
Posted on Dec 13, 2009
honeymokey
  • 3113 Answers
SOURCE: CLEAN SOFTNER DISPENSER
It snaps in. No need to clean it as it cover the agitator cams or dogs.
Posted on Mar 03, 2010
The fabric softner cup will not drain
I don't know the solution to this either. Both my Whirlpool, front load washers: old one (15years old) and new one (2 months), the softner itself is always drained into the wash and residual water is there at the end of each wash.
Dec 20, 2010 | Samsung WF337AAL Front Load Washer
Dec 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine
hi if your softner dispensor is a removable compartment from the soap powder drawer ? then remove the dispensor and you will see the pipe with cap on top at rear ? pull this pipe off and ensure it is not blocked and that the cap is a firm fit on top? then ensure the short pipe that is part of dispensor tub is clear reassemble and refit try again ? these softner dispensor work by syphon effect IE when you top up to recommended level with softner in dispensor ? it remains untill wash is at softner rinse cycle then when water is entered into dispensor of softner and the level is raised to above the short pipe within compartment and the outer pipe with top on ? the syphon effect takes place and the softner+waterlevel is is syphoned int machine and dispensor is empty?? i hope you understand ? it is simple and works if you think of a toilet cistern how it syphons water for flush it is the same principle hope this helps
Oct 30, 2008 | LG Washing Machines
Fabric softner part
The machine will work fine without the fab softner piece. A new one can be ordered and you will be able to replace the broken one.
Any other questions please ask.
Thanks,
Bill
Oct 16, 2008 | Kenmore 24032\24036 Top Load Washer
Tricity bendix AW1053W front loading
Either you have a clogged line going from the compartment to the tub or the valve is sticking for the softner.
Sep 14, 2007 | Kenmore 23822 Top Load Washer
Fabric softner leakage
By opening upper machine's cover you will have an access to the detergent/softner drawer. Look for the place the water leaks from. Good luck !!
Sep 03, 2006 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
