Question about JVC TH-C50 System
Subwoofer turns on with the light and after few seconds its shuts off automatically
Hello, hope you can please help, my subwoofer TH-C50 System is not working. Whenever we are turning it on, it lights up but after few seconds it shuts off. I have tried plugging it on in a different outlet coz i thought that the problem is power supply but its still the same. Tried checking the 7 pins after reading some suggestions here but nothing happens. Please help
Nightdiver
  • 116 Answers
SOURCE: Subwoofer JVC TH-M606
What system are you using it with, how do you have it connected, when you say the system does not work as a result, does it mean that the system does not power up, or no sound?
Posted on May 19, 2006
bluenadas
  • 203 Answers
SOURCE: SUBWOOFER WON'T POWER ON (Grounding out???)
Check your cable that runs between the main unit and sub for bent pins. If they look fine there may be a short in the sub itself that is causing it to go in to shutdown.
Posted on Jun 15, 2007
s4u311
  • 813 Answers
SOURCE: JVC TH-A9
1st u need to covert stereo cable with stereo conversion pin which avelieible in electronic consumer store after u got this cable u able to connect ur speakers directly to play station or a tv
Posted on Feb 19, 2008
SOURCE: JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
Posted on Apr 10, 2008
SOURCE: jvc th-c6 subwoofer won't turn on
Check the little prongs inside of the cord, they are very fragile and if they get pushed in wrong, bent and broken off - you would never see one on the floor. These should all be straight and be able to make contact. Hope this helps!
Posted on Mar 16, 2009
I have a Th-C50 home theater and lost my subwoofer system cord, can I use a regular s-cord to make that connection? or is it useless with out the cord?? Please help!
Yes you can use any 2-core cable to carry the bass signal to the subwoofer. As the bass speaker cone is the largest cone in your speaker set I would recommend a good quality cable of decent gauge (thickness) to carry the bass signal.
You just need to make sure you have the right connectors for the amp and sub and make sure you connect positive to positive and negative to negative.
Hope this helps,
Chris
Mar 02, 2011 | JVC TH-C50 System
SUBWOOFER WON'T TURN ON
hello the most common reason for those subs not turning on is the din jack on the back of the sub where the 7 pin cable plugs in is worn --to confirm simply wiggle it while the dvd is on it will pop and possibly startle you but 9times out of 10 its just the jack
Sep 08, 2010 | JVC TH-C50 System
Subwoofer JVC TH-M606 suddenly stopped functioning
Hiya, sorry that will have to go in for repair as it sounds like it may be protecting. Could be something loose but that would be lucky. Suggest finding a electronics shop in area that can assist. Best of luck
Jul 14, 2009 | JVC TH-M606 System
Jvc th-m45 shut off
shut off audio system is performed to protect it from damage due to high current consumption or short circuit in speakers try to disconnect subwoofer first and check if it is ok. the problem in your subwoofer or its cord-change the cord and check if it is ok thats fine if not change subwoofer.do the previuos for all speaker one by one.
if all above failed you must contact service center for help.
Apr 06, 2008 | JVC TH-M45 System
Sub woofer shuts off
please check sub cable first with another good one and then change sub itself.because it draw too much power.
Jan 05, 2008 | JVC TH-C50 System
Th-R1 no pwoer to subwoofer - transformer u/s?
my power goes to the subwoofer and the little green light comes on for just a second and the you hear a click sound and the subwoofer power goes out. I have the JVC DVD Digital Cinema System TH-C90. Can you please help???
Oct 14, 2007 | Audio Players & Recorders
Subwoofer Shutdown
Whay don't you take a look at your data cable and jack contacts to see if any of them are bent or misplaced. Terry
Oct 02, 2007 | JVC TH-C50 System
Oct 21, 2006 | JVC TH-M505 System
Subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Sep 10, 2006 | JVC TH-M505 System
JVC TH-C50 System Logo
116 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
