Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Washing machine The washer will not turn on. I replaced the fuse in the upper left side of the body of the washer. The washer runs for four loads and stops again. The blows again.
    President:
  • Maytag Master
  • 2,651 Answers
Most likely a problem with your lid switch assy assuming the correct model LSE7806 ,part number 12001514
Posted on Oct 26, 2008
Washer leaking water on floor
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps...
Daniel
Feb 11, 2011 | Frigidaire GLET1031WH Top Load Stacked...
Water leaking from bottom of washer between the washer and petestal
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps... Please post back if you need more information.
Daniel
Dec 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Top Load Stacked Washer / Dryer Maytag lse7806ace -- washer will not run, except in spin cycle
I believe there is a fuse on the left side front under the front panel about a foot from the top of the washer.
Nov 20, 2010 | Maytag LSE7806A Top Load Stacked...
I have an elite kenmore top load washer. With the lid closed the washer will fill with water, but the wash or spin cycle will not start unless the lid is gently pushed down on the upper left side of the...
Lid switch has gone bad...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 22, 2010 | Kenmore Washing Machines
Leaks out the front of machine
Hi
Daniel
Sep 01, 2010 | Roper RAS8445KQ Top Load Washer
WATER IS COMING OUT FROM THE BOTTOM OF MY WASHER,IS THIS SOMETHING MAJOR?
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly is it leaking, inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. to replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps...
Daniel
Aug 30, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer is shaking alot and makes unreal noise. Like it is out of balance
On front load washers, it is very important that the washer be truly level and that all four (adjustable) feet are screwed down so the whole washer absolutely does not rock forward to back or side to side.
The floor needs to be solid and not "deflect" when you walk on it.
But if the above items do not solve the problem, then it is almost certain that one or both of the shock absorbers has broken. They can be seen under the wash tub but removing the front kick plate and looking in. They look like tiny car shock absorber / struts. Grab one and push / pull or run a load with the cover off and watch as the washer spins up.
The shocks are not incredibly hard to replace yourself if you are inclined and the instructions provided with the replacement parts are pretty clear.
There are other possible failures besides the shocks, including the upper springs and a failing main bearing, but that is rare on newer model washers.
Note that the most common cause of shock or spring failures is when the washer is relocated and the wash drum is not locked down per the instructions provided with the washer.
Please report back what you find, OK?
May 21, 2010 | Kenmore Elite 45986 Front Load Washer
Water won't run into washer - clicking sound only front upper left like plastic gears running over each other
The fill valve is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore Washing Machines
Whirlpool washer shaking and vibrating how do we get to springs and pads
To eliminate the vibration and the movement of your washer you need to align the four legs of your washer using level tools. Just put the level on the top of the four sides (front side, left side, right side and backside and then make necessary adjustment if needed on the 4 leg of the washer.
Feb 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer moves during the spin cycle
Due to strong vibration during spinning definitely the machine will stop. All you have to do is to check your load if equally distributed from the tub. To eliminate the vibration and the movement of your washer you need to align the four legs of your washer using level tools. Just put the level on the top of the four sides (front side, left side, right side and backside) then make necessary adjustment if needed on the 4 leg of the washer. Also check the water level of the balancer and the mounting position from the top of the tub.
Jan 31, 2009 | Whirlpool LSR5132PQ Top Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
109 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
